Truck 727 in an a-body #267825
03/26/09 11:36 PM
03/26/09 11:36 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Got a chance to get a small block 727 from a 74 Ram. I haven't seen it yet but will this fit in a 72' a-body? Any reason I shouldn't use a truck tranny?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Truck 727 in an a-body [Re: busboy] #267826
03/26/09 11:41 PM
03/26/09 11:41 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Is the 74 trans a 4wd or short tail shaft ?
Re: Truck 727 in an a-body [Re: dOoC] #267827
03/26/09 11:44 PM
03/26/09 11:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it's the long tail shaft then no problem.
Re: Truck 727 in an a-body [Re: stumpy] #267828
03/26/09 11:48 PM
03/26/09 11:48 PM
busboy Offline OP
busboy  Offline OP
I was told it's the long tail shaft, but I haven't seen it yet. I should get a look at it in the next couple days. Thanks
Re: Truck 727 in an a-body [Re: stumpy] #267829
03/26/09 11:50 PM
03/26/09 11:50 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
Just make sure it dont have the right side boss mount on the tail shaft housing. I did this 5 years ago with a 70 Swinger and a 727 from a 73 Adventurer and ran into that. Everytime you hit a good bump or banged the gears it would hit the side of the tunnel real hard. Luckily a local trans builder had a tailshaft lying around and cleaned it up for me with a new bushing and seal.Free at that! I changed it out in the car in about an hour.Very simple.
'71 383HP FJ6 Charger SE
Re: Truck 727 in an a-body [Re: 71 FJ6 Charger] #267830
03/26/09 11:52 PM
03/26/09 11:52 PM
NE Ohio
NE Ohio
If you need,I can post a pic of the tail housing with the side mounting boss on it so you can see what I mean.PM me or reply here.
Re: Truck 727 in an a-body [Re: busboy] #267831
03/26/09 11:53 PM
03/26/09 11:53 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
IF it is a short-shaft .. it is still OK. But you have to change that to be usable in a car.
Re: Truck 727 in an a-body [Re: 71 FJ6 Charger] #267832
03/27/09 12:20 AM
03/27/09 12:20 AM
busboy Offline OP
busboy  Offline OP
Thanks Bee, if you post the pic here everyone can get a look.
Re: Truck 727 in an a-body [Re: 71 FJ6 Charger] #267833
03/27/09 12:23 AM
03/27/09 12:23 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I had the same thing in my 68 Barracuda when I got it. Took me a while (and lots of motor mounts) to figure it out.
Re: Truck 727 in an a-body [Re: autoxcuda] #267834
03/27/09 08:27 AM
03/27/09 08:27 AM
scratchnfotraction Offline
yep,I ran a 727 short shaft in a 68 Dart
built a drive shaft with a slip yoke
people told me it would not fit,but it bolted right up and cleard the cross member with the bolt on yoke
I would do it again...
tranny shop looked at it once,then called all the guys out to look at it..they are the ones said it cant be done
left some in the parking lot for em
never say never with mopar,the A-body 8 3/4 is in my 85 truck now bolts right in
Re: Truck 727 in an a-body [Re: scratchnfotraction] #267835
03/27/09 10:01 AM
03/27/09 10:01 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
The truck has a long shaft? Like the B body trannies? 833OD's?
Like A body 4 speeds are short, so is the autos?
I have a 727 from a van-long.
Short 727 from a 3/4 ton BB club cab 2 piece driveshaft. No slip yoke
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Truck 727 in an a-body [Re: Rug_Trucker] #267836
03/27/09 10:07 AM
03/27/09 10:07 AM
yep mine came from a 76 club cab long bed
short 727 long 2 piece shaft
worked for me
Re: Truck 727 in an a-body [Re: scratchnfotraction] #267837
03/27/09 10:12 AM
03/27/09 10:12 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If the pickup is a 2 wheel drive standard cab small block unit it will have the standard long tail shaft. If it is from a 4X4 or truck with a split drive shaft with hanger bearing it will work but the transmission will have to vertually completely disassembled and the long tail shaft and housing installed or like in the above post with the short shaft truck reverse type drive shaft may be able to be used if the but you may also have to work around the park brake drum. Doing this you will have an excessively long drive shaft and it will be very prone to vibration.
Re: Truck 727 in an a-body [Re: MoparforLife] #267838
03/27/09 10:19 AM
03/27/09 10:19 AM
mine did not have the park drum...just a bolt on yoke
Re: Truck 727 in an a-body [Re: busboy] #267839
03/27/09 03:48 PM
03/27/09 03:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The upper tailhousing in the pic below is the truck type with the side access plate, a tight fit in some passenger cars.
Re: Truck 727 in an a-body [Re: John_Kunkel] #267840
03/27/09 04:09 PM
03/27/09 04:09 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I ran one in a 72 Duster and nevr had a problem, they don't have a place to bolt floor shift linkage though.
Mitch
Re: Truck 727 in an a-body [Re: 500ciDuster] #267841
03/27/09 04:43 PM
03/27/09 04:43 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Mitch
Again, easily fixed by swapping the tail shaft.
Re: Truck 727 in an a-body [Re: WILD BILL] #267842
03/27/09 09:36 PM
03/27/09 09:36 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I did swap the shaft to the trucktail since I had a B&M shifter and my friend needed a car tailshaft so his floor shift would work in his challenger.
Re: Truck 727 in an a-body [Re: 500ciDuster] #267843
03/27/09 09:49 PM
03/27/09 09:49 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
truck one hit the floor in the one I tried. I swap them now.
