spot weld cutters #267789
03/26/09 10:58 PM
03/26/09 10:58 PM
Massachusetts
N
NortheastMopar Offline OP
N
Massachusetts
What size spot weld cutter do you use? What size hole do you drill in a new repro panel to give a look of spot welds when filled with the mig?
Re: spot weld cutters [Re: NortheastMopar] #267790
03/26/09 11:26 PM
03/26/09 11:26 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
I use 3/8 cutters mostly, as I find the smaller ones don't separate as clean. The larger cutters don't last more than a handfull of welds. Best ones are the cheapies on ebay from jim at kestors services, eBay Member: ksjimmyk, they last just as long as my $40 zebra bits...but cost next to nothing.. and he sharpens them when they are worn. Size the new hole according to the size of weld you want to create, it takes practice to get a plug to look like a spot, most guys will just grind them flush and use an eraser in the wet primer to simulate a spot weld. Works great! I cheat.. I use a spot welder to recreate spot welds!
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: spot weld cutters [Re: NortheastMopar] #267791
03/27/09 12:20 AM
03/27/09 12:20 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I used these Harbor Freight cheapies recently. I thought they worked fine. I bought 5 at $1.99 each. I think I could have only used 1 and gotten the whole interior floor pan out. But I did grab another one in tight areas. They are double sided. I used wd-40 to help them along, just don't press too hard. My only concern was if the 3/8 was too small as my pans had several spot welds which seemed right on top of each other. Overall, the spot weld cutter, an air chisle, and some cut off tools did a decent job. However, I think you could probably just drill out the flanges just as easily front and back.
Re: spot weld cutters [Re: moparmojo] #267792
03/27/09 12:41 AM
03/27/09 12:41 AM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
If it is a brand new repop panel just drilll with a 3/8 pilot point bitt and weld the holes closed up.
I was going to use the spot cutters i have to get the old ones out then grind the car flat and weld the new ones in as I posted above.
Does Harbor Frieght sell the ones you posted in store? I did not see them.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: spot weld cutters [Re: 340SIX] #267793
03/27/09 02:28 AM
03/27/09 02:28 AM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
I was using the less costly (didnt know there was an alternative at the time) spot weld cutters for quite some time until I discovered the Blair 11094 spot weld cutter.
The 11000 series Blair will cut spot welds in a fraction of the time it takes with the older double ended type cutter. I was so impressed with the 11094 I gathered up all of my other spot weld cutters (some of which the blades were unused) and promptly pitched them in the scrap metal container.
Best of all- MADE IN THE USA Blair
See cutter at upper left side of page.
Re: spot weld cutters [Re: mr_belvedere] #267794
03/27/09 03:24 AM
03/27/09 03:24 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I use only Blair Rotobroaches here. They last the longest and I get hundreds of cuts out of one blade. Correct speed and lubrication is the key.
Primarily 5/16 and 3/8 cutters
The other alternative is a plasma cutter set to cut the first layer of material. Works really good and much faster/cleaner than anything else.
Re: spot weld cutters [Re: RobX4406] #267795
03/27/09 08:20 AM
03/27/09 08:20 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Wow never seen that done. My plasma is not adjustable, can you tell us more? I have more welds to cut on my current project.
I used all of them over the years, I think of the roto broach as being the most durable. But I still wound up using a reg drill bit and think it works and lasts the best. I can resharpen a drill bit in seconds.
Re: spot weld cutters [Re: Challenger 1] #267796
03/27/09 08:43 AM
03/27/09 08:43 AM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Sharpen a drill to look like this and you will never buy a spotweld cutter again. Mike
Re: spot weld cutters [Re: NortheastMopar] #267797
03/27/09 11:50 AM
03/27/09 11:50 AM
Spotweld cutters are only needed when you want to re-use the outer panel.If you are tossing the outer panel,then just use a zip disc to "erase" the spotweld until the two panels pop loose.This way there is less work involved,and less damage to the lower panel.
If you use a spotweld cutter,you will still need to grind off the button that is left over,plus spotweld cutters are way to easy to go too deep and cut into the lower panel that should not be harmed.
I have been doing panel replacement daily for almost 25 years,and this is by far the quickest and simplest method
Re: spot weld cutters #267798
03/27/09 12:30 PM
03/27/09 12:30 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
What is a zip disc and where do you buy it?
Re: spot weld cutters [Re: gtx69] #267799
03/28/09 01:47 AM
03/28/09 01:47 AM
A zip disc is another name for a cutoff disc.The 3" diameter abrasive cutoff discs that fit on a handheld cutoff saw.Use the thicker version rather than the thinnest,or double up two thin ones if that is all you can find.The thin ones are very thin-about 1/32" I guess,and can be flexed somewhat with your fingers,the thicker ones are about 1/16".
Re: spot weld cutters [Re: 340SIX] #267800
03/28/09 06:00 PM
03/28/09 06:00 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Yes, the cheapies can be bought in the store (Harbor Freight) in the cut off wheel section I believe. Matter fact, I just saw them advertised in the latest ad for $2.99. I got mine for $1.99 with a coupon I had. But still they are fairly cheap and I thought they have worked well, however, I have never used any of the name brand ones.
