Pro comp rockers #2676691
07/11/19 11:54 PM
07/11/19 11:54 PM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
Just bought a set of bbm pro comp rockers. They have bushings in them. Does anyone know what these bushings are made of, why bushings. Why not the aluminum body.
Re: Pro comp rockers [Re: 72sat] #2676698
07/12/19 12:37 AM
07/12/19 12:37 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
They are sleeved....with coated copper I believe. They work great! Haven't had any issues with them or the valve covers off all season so far. I did size a lot of the spacers to fit though during the build process. I have a lathe so it was no big deal.
Re: Pro comp rockers [Re: 72sat] #2676741
07/12/19 08:39 AM
07/12/19 08:39 AM
WA 98043
thecarfarmer Offline
WA 98043
Why not just run the aluminum body directly on the steel shaft?
1. Anywhere whatsoever basically totals the rocker, unless you have the facilities to board the hole oversized (without altering its location), and then put a bushing in. for something made with a replaceable bushing, you press the old one out, press the new one in, ream or hone to size. Your component is now far more easily kept serviceable, with just an arbor press and a drill press.
2. Aluminum is not a really great bearing material against Steel. If there is ever a problem with it running dry, it's fairly prone to galling. Brass and bronze have much better inherent lubricity, and are more forgiving of occasional insufficient lube.
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Pro comp rockers [Re: thecarfarmer] #2676744
07/12/19 09:32 AM
07/12/19 09:32 AM
Dragula Offline
Dragula  Offline
Because they are not aluminum...
Re: Pro comp rockers [Re: Dragula] #2676748
07/12/19 09:43 AM
07/12/19 09:43 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Good one captain obvious haha
Gus beer
64 Plymouth Savoy
Dana 60
Re: Pro comp rockers [Re: 72sat] #2676809
07/12/19 12:54 PM
07/12/19 12:54 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Check the rollers over the valve tips for wear.
Not pro-comp, but CAT rocker I had the rollers really starting wearing.
Really my cheap CAT stainless rockers, the rocker bodies are nicely made with good geometry, but everything else like was sub-par.
I still have them, and though of rebuilding them with quality adjusters and roller tips, but that is more cost than I paid for the entire setup.
