Where to get KH a body calipers/parts from? #2676697
07/12/19 12:33 AM
07/12/19 12:33 AM
Oregon City, OR
Baxter61 Offline OP
Baxter61  Offline OP
Oregon City, OR
Where do y’all get your brake parts from? There was a vendor listed years ago that rebuilt the 4 piston calipers with stainless sleeves, etc but I couldn’t find the link.
Re: Where to get KH a body calipers/parts from? [Re: Baxter61] #2676729
07/12/19 07:53 AM
07/12/19 07:53 AM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
There is a guy over on 'for a-bodies only.com that totally rebuilds that stuff and does a great job at it! He goes by hemi71 I believe? I bought a set of refurbished lower control arms from him and they were VERY nice! Last I knew, he had a set of redone K-H calipers in the for sale section over there.
Re: Where to get KH a body calipers/parts from? [Re: mopower440] #2676756
07/12/19 10:04 AM
07/12/19 10:04 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The pistons and seals can be found on Rock Auto. The pistons ride on a rubber o-ring so minor bore pitting is not a deal breaker from what I can see.
Re: Where to get KH a body calipers/parts from? [Re: mopower440] #2676767
07/12/19 10:36 AM
07/12/19 10:36 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Well, that would be me.
Thank you for the "heads up" on the quality of my work.
To the OP.
Pretty much Rock Auto has the caliper parts you would be seeking.
Pistons, rebuild kits, pads, pad hold down clips.
If you need hard lines, pick your poison, Fine Lines, Inline Tube, Classic Tube.
Calipers themselves, are pretty much out of stock these days.
Not enough "cores" are out there anymore, to be put back into service.
Yes, i do have a rebuilt pair of them that are up for sale.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Where to get KH a body calipers/parts from? [Re: Neil] #2676771
07/12/19 10:52 AM
07/12/19 10:52 AM
hemi71x Offline
hemi71x  Offline
That is correct.
Kelsey Hayes, 4 piston calipers do not have to be sleeved.
The piston seal is in the top bore of the caliper body, and not on the piston itself.
Don't worry about it, if caliper bores have pitting, after you sandpaper them up, cleaning them up.
Bad caliper bores in the BENDIX, and BUDD, disc brake systems, require sleeving, if they are bad, due to their piston design, and sealing.
Kelsey Hayes, is a good design.
