Pushrod adjusters cup of ball #2676693
07/11/19 11:57 PM
07/11/19 11:57 PM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
Is there an advantage one over the other?
Re: Pushrod adjusters cup of ball [Re: 72sat] #2676704
07/12/19 01:33 AM
07/12/19 01:33 AM
What application are you wanting to know about, street, street and strip or race only and intended HP and RPM? shruggy
All out drag race with high RPM and high spring pressures then you would end up with a paired shaft rocker system that uses ball and ball pushrods only shruggy
I have used many sets of Harland Sharp rocker arms on many 800 +HP lower RPM(below 8000 RPM)race motors with single shaft rocker set ups with ball and cup with no issues also work shruggy
Re: Pushrod adjusters cup of ball [Re: Cab_Burge] #2676707
07/12/19 02:49 AM
07/12/19 02:49 AM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
All out racing on the street high rpm, mostly thinking about good geometry , at high rpm BBM.
Re: Pushrod adjusters cup of ball [Re: 72sat] #2676798
07/12/19 12:37 PM
07/12/19 12:37 PM
On that deal I would go with either the Jesel paired shaft set up or the T&D paired shaft set up with 1.7 or higher ratio rockers with a custom ground cam for the RPM you want to shift at scope
I advise all my customers to stay under 8000 RPM on most BB motors I build, I say that due to not having any real hands on experience with a motor shifted above 8000 RPM yet.
I have most of the parts to build a 555 C.I. B1-MC headed motor with a Koleno high nickel iron block with a good rocker arm set up like mentioned above. Most of the B1-MC motors I have heard of like to be shifted around 8600 RPM shruggy
My current bracket motor with the Jesel set up with 1.55 ratio rockers has not been shifted above 7200 RPM so far, I will experiment with different shift points on it later this year. I've had it out four times so far and have not had the time at the track to try shifting it higher yet do to other new motor issues including ignition problems with E85 at 15.0 to 1 compression ratio rant whiney shruggy
I really like the Jesel set up as it is easily adjustable on the height of the paired shaft set up to correct the geometry up scope Not cheap though, mine was included on a pair of Indy 440-1 heads I bought so I had nothing to do with the ratio on them.
Go with steel rocker arm kit, not aluminum now tsk
This motor has right at 325 lbs. on the seat pressure and a little over 875 Lbs. over the nose, on the engine stand it turns over really smoothly once you get it turning ,not like all the other motors that I have built with the single shaft set ups with similar spring pressures work
Good luck on your deal wrench
Re: Pushrod adjusters cup of ball [Re: Cab_Burge] #2676801
07/12/19 12:42 PM
07/12/19 12:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Especially valuable with a dual pattern cam
Boffin Emeritus
Re: Pushrod adjusters cup of ball [Re: 72sat] #2676859
07/12/19 04:20 PM
07/12/19 04:20 PM
Washington
madscientist Offline
Washington
[quote=72sat]All out racing on the street high rpm, mostly thinking about good geometry , at high rpm BBM. [/quote
Call Mike at B3 racing engines and tell him what you are doing. It will save time and money in the long run.
