Coil on plug? #2674397
07/05/19 11:46 AM
07/05/19 11:46 AM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
Just wondering what voltage is needed to fire E85 with 14:1 comp?
Hoping to run coyote 5.0 coil on plug assembly but not quite sure if the voltage is high enough to run at higher rpms
Thanks for any and all info
Kevin
Re: Coil on plug? [Re: 604 Hemi GTX] #2674475
07/05/19 03:42 PM
07/05/19 03:42 PM
AndyF Offline
AndyF  Offline
I don't understand your question. Are you asking about battery voltage? I don't see any reason why 12 volts wouldn't work just fine. There are a lot of guys making really big power with Holley Smart Coils and 12 volts. You do need to follow the instructions in terms of dwell time.
Re: Coil on plug? [Re: AndyF] #2674480
07/05/19 04:05 PM
07/05/19 04:05 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think he is concerned about secondary voltage being sufficient to flash off alcohol at 14:1 compression.
Kevin
Re: Coil on plug? [Re: Twostick] #2674531
07/05/19 05:49 PM
07/05/19 05:49 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
That is not an issue. Those coils are used on blown alcohol motors.
Re: Coil on plug? [Re: AndyF] #2674617
07/05/19 09:32 PM
07/05/19 09:32 PM
ONTARIO,CANADA
ONTARIO,CANADA
Sorry I should of specified secondary voltage
Kevin
Re: Coil on plug? [Re: 604 Hemi GTX] #2674649
07/06/19 12:02 AM
07/06/19 12:02 AM
AndyF Offline
AndyF  Offline
I haven't used the Coyote coils but I've used the Holley Smart coils on a few different engines. People use the smart coils on 3000 hp engines. The nice thing about that setup is that it doesn't require a big expensive MSD box. The coils just get the signal from the ECU and fire. The spark plug leads are nice and short and each coil only has to fire 1/8 of the time that a normal coil has to fire. I can't see how you would have any issue at all in a NA application.
