Re: Education on small blocks
[Re: hudsonhornet7x]
#2674086
07/04/19 03:20 PM
07/04/19 03:20 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
I know very very little about small blocks because I'm mostly a Hemi guy. But I do know this: If I was going to ever run a small block, it would be a NASCAR engine. Those things are pretty cheap, readily available, and they definitely have got some snort!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
#2674274
07/04/19 11:47 PM
07/04/19 11:47 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thank you guys, I think a big inch small block would be a blast. I have read about the Ritter blocks and problems. Do you think the problems are behind them? How fast are you looking to go and at what weight? A stock Small block will hold up to quite a bit.
#2675453
07/08/19 09:54 AM
07/08/19 09:54 AM
Posts: 3,519 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Thank you guys, I think a big inch small block would be a blast. I have read about the Ritter blocks and problems. Do you think the problems are behind them? While I don't have one, it sounds like the Ritter blocks are ready for prime time. However if I did get one, I would make sure it was a "latest version" and I would have a top notch machine shop check if fully before using it.
