Lets see brakeline photos on BB fenderwell header cars.
#267334
03/26/09 01:37 PM
03/26/09 01:37 PM
Posts: 876 Arizona
PolyDart
Arizona
I would like to see how you have installed your brake lines, distribution block/proportioning valve and line lock on A body, big block cars, with Supercomp fenderwell headers. If you've got'em let's see'em. Thanks!
Re: Lets see brakeline photos on BB fenderwell header cars.
[Re: PolyDart]
#267335
03/27/09 10:42 AM
03/27/09 10:42 AM
Posts: 876 Arizona
PolyDart
Arizona
[Re: PolyDart]
#267337
03/27/09 04:55 PM
03/27/09 04:55 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
Sorry but no picture. I routed the lines from the master into the passenger compartment. The proportioning valve and line-lock is behind the drivers side kick panel. The brake lines got back out through the floor to the wheels.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: Dave_S]
#267338
03/27/09 10:32 PM
03/27/09 10:32 PM
Posts: 2,364 PA
70HemiGTX
PA
I just rerouted them out of the way toward the firewall and down to the stock position of the proportioning valve. I also have my linelock right by the valve. Everything is on the inside of the frame. Don't know how well the pictures will show up. Actually can't see a darn thing. I will try to get some pics tomorrow for you.
[Re: 70HemiGTX]
#267339
03/27/09 11:22 PM
03/27/09 11:22 PM
Posts: 876 Arizona
PolyDart
Arizona
[Re: 70HemiGTX]
#267340
03/28/09 12:02 AM
03/28/09 12:02 AM
Posts: 502 Huron, South Dakota, United St...
dustyhof
Just wondering, but, I just went through all the work of moving all my brake lines out of the stock position, because it was right next to the flywheel. Does'nt NHRA rules require all brake lines inside the frame rail to be surrounded by 1/8" thick steel tubing 16" long?
