W9-RP Head Studs? P5007912 #2672924
07/02/19 10:03 AM
07/02/19 10:03 AM
Texas Afghanistan Iraq etc.
DakFink Offline OP
DakFink  Offline OP
I need to know what the specs are for the $1200 Mopar Head stud kit. Part Number P5007912
Most places are running out of stock so they are getting hard to find.
That said, I talked to ARP a few months back and they said they had nothing in their listings for the W9-RP. BUT if I had the specs they could get something together for me.
I know they are 1/2" dia. in the block and 7/16" dia. through the head. There are 3 different lengths. 2 sets are 10 pieces and 1 set is 16 pieces. 12-point nuts.
If I can get the lengths I think they could figure out the rest and put together an affordable set.
If someone knows all the details that would be awesome.
I used to have a set but "Storage Thieves" wanted them I guess!
Re: W9-RP Head Studs? P5007912 [Re: DakFink] #2672947
07/02/19 10:36 AM
07/02/19 10:36 AM
W. Pa
U
usp4u Online content
usp4u  Online Content
U
W. Pa
Not sure I the RP studs are different, but Kent Ritter put me together my sets of 'stepped' W9 studs. Was much more affordable than tracking down pre-packaged kits.
Re: W9-RP Head Studs? P5007912 [Re: usp4u] #2672966
07/02/19 11:06 AM
07/02/19 11:06 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
There’s a place called Allens Fasteners on the net. They carry individual arp studs. I realize what you need are the actual dimensions, but you can come up with that by measuring the head/ block.
Re: W9-RP Head Studs? P5007912 [Re: TRENDZ] #2672970
07/02/19 11:17 AM
07/02/19 11:17 AM
DakFink Offline OP
DakFink  Offline OP
I don't have the Block/Heads with me. They're at Bondo's house and was hoping someone might be in the know.
Re: W9-RP Head Studs? P5007912 [Re: usp4u] #2673000
07/02/19 12:41 PM
07/02/19 12:41 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Curious as to why regular W9 heads would need "stepped" studs. The ones I use with my W9 heads are not stepped.
Thanks!
Re: W9-RP Head Studs? P5007912 [Re: 340Cuda] #2673016
07/02/19 12:58 PM
07/02/19 12:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks!
My W-9 stuts werent stepped down.. sorry to to the OP but I dont recall
the lengths
wave
Re: W9-RP Head Studs? P5007912 [Re: DakFink] #2673018
07/02/19 01:03 PM
07/02/19 01:03 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
You might contact member 69 lawndart. He has/had and engine with W9 RP heads.
Re: W9-RP Head Studs? P5007912 [Re: 340Cuda] #2673035
07/02/19 01:42 PM
07/02/19 01:42 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Here is a cutaway of a rp head. The entire row of bolts between the ports are 7/16. The heads are much taller than a standard w9 also.
Re: W9-RP Head Studs? P5007912 [Re: TRENDZ] #2673077
07/02/19 02:47 PM
07/02/19 02:47 PM
DakFink Offline OP
DakFink  Offline OP
The heads I have!
Re: W9-RP Head Studs? P5007912 [Re: DakFink] #2673079
07/02/19 02:52 PM
07/02/19 02:52 PM
DakFink Offline OP
DakFink  Offline OP
Here's Pictures of the studs I had. After another look it doesn't look as though they are stepped. BUT do have 2 different thread pitches on each end.
There also appears to be 2 diameters and 3 lengths.
I did look at some Chevy SB2 heads and studs and they look close?
Re: W9-RP Head Studs? P5007912 [Re: DakFink] #2673191
07/02/19 04:17 PM
07/02/19 04:17 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would say those are stepped down.
On a regular W9 stud the thread is the same size as the stud, not larger like the one shown.
Most all studs have coarse threads for the block and fine threads for the nuts on the head side.
