Page 3 of 3 1 2 3
Re: 440 Blocks [Re: LA360] #2672844
07/02/19 05:10 AM
07/02/19 05:10 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Originally Posted by LA360
Originally Posted by DusterKid
Plus there's just something about the sound of a BB that a SB can't make.
Is it7 because they're like a kid with asthma trying to run?
Ouch
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 440 Blocks [Re: tex013] #2672848
07/02/19 05:55 AM
07/02/19 05:55 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
I ran an injected alcohol 499 low deck for approximately 10 years, 1-300 1/8 mile passes every year, 750ish hp, arp main studs and aluminum main caps, eagle crank, rods and Ross pistons, half fill, finally cracked a cylinder wall on #8...never saw a web crack...shifted at 6800, don't know if it makes a difference but this block was first in a hardtail pipe rack then a 4 link pipe rack, spanned 1998 to 2008. Scattered it all over Denton Dragway after sleeving the cracked #8 hole...( 5 Dyno pulls, 3rd pass down the track) damage was do severe myself and 2 "experts" couldn't figure out what let go first...managed to save the intake, distributor and fuel injection system...oh yeah and valve covers...(most likely suspect was something to do with 7&8 rod journal)...
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: 440 Blocks [Re: LA360] #2672940
07/02/19 10:26 AM
07/02/19 10:26 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Is it because they're like a kid with asthma trying to run?
laugh2
72 Plymouth Roadrunner 11.08@123.25
Re: 440 Blocks [Re: Roughbird72] #2672958
07/02/19 10:47 AM
07/02/19 10:47 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
It doesn’t take much of a small block to make the big blocks look silly. How many 340-360 blocks do you hear about cracking. 😂
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 Blocks [Re: DusterKid] #2672961
07/02/19 10:55 AM
07/02/19 10:55 AM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
This 440 block still ran fine , low 10's , but smoked a bit...
Re: 440 Blocks [Re: als499] #2672985
07/02/19 11:43 AM
07/02/19 11:43 AM
Washington
madscientist Offline
Washington
Looks like the number 4 cylinder is cracked WAY up the bore. It must be filled or it would have put coolant in the oil.
Re: 440 Blocks [Re: madscientist] #2672988
07/02/19 11:56 AM
07/02/19 11:56 AM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
#2 ,#3, #4 main saddles were cracked up into the cylinders and the block was getting ready to split in half, no concrete.
Re: 440 Blocks [Re: als499] #2672999
07/02/19 12:39 PM
07/02/19 12:39 PM
central il.
second 70 Offline
second 70  Offline
central il.
When I broke one back in the seventies it was so bad the only thing keeping the back of the block from falling to the ground was because the starter wire was holding it on.
Re: 440 Blocks [Re: tex013] #2673376
07/02/19 09:03 PM
07/02/19 09:03 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
Ouch
Tex
You have to admit, the BBM heads out there aren't exactly setting the world on fire in terms of airflow/cross section. No idea what the Chrysler engineers were thinking really.
No offense intended to anyone with asthma!
Alan Jones
Re: 440 Blocks [Re: LA360] #2673422
07/02/19 11:16 PM
07/02/19 11:16 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Ouch
Tex
No offense intended to anyone with asthmTa!
I guess it was hemi
those max wedge ports work , nearly as good as a sbc
Tex
New best MPH 130.32
Re: 440 Blocks [Re: tex013] #2673431
07/02/19 11:33 PM
07/02/19 11:33 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
# 2 main explosion. 383 600+hp
Re: 440 Blocks [Re: RemCharger] #2673499
07/03/19 08:26 AM
07/03/19 08:26 AM
an8sec70cuda Offline
I have not cracked one, but the highest HP I've put through one at the track was around 620 hp.
It was/is a 14:1 stock stroke 440 that ran 10.40s at 128-129 mph at 3700 lbs. Ran it for a lil over 3 years and never hurt it.
That same motor is in another car but is making around 700 hp now. It is probably a time bomb, but I'll run it til it dies...if I ever get the rest of the car track worthy.
I know Mike Daurity split the main webs and a couple cylinder walls in his low deck 512/400 stroker in his street car '69 super bee a few years ago. It's around 600 hp on motor plus a small plate system.
CHIP
'06 GMC 2500HD LBZ Duramax
Page 3 of 3 1 2 3
