Re: Carbs evaporating gas ?
[Re: 420SIX]
#2672842
07/02/19 04:50 AM
07/02/19 04:50 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Today's gasoline is formulated for closed injection systems with no regard for evaporation qualities.
Back in the 60s and early 70s, gasoline was formulated to retard evaporation, since almost every car had carburetors open to the atmosphere.
So yes, today's gasoline evaporates much faster than back then.
The plus side is, when the gas evaporates, it does not leave the varnish and other crud that it used to.
The solution is to spray carb cleaner in the intake to allow the engine to start up and pump gas into the bowl. Either that or install an electric fuel pump to be used temporarily during start ups after the bowl goes dry. But don't plumb it so the mechanical pump is trying to pull gas through the electric pump - that won't work.
[Re: kentj340]
#2672898
07/02/19 08:58 AM
07/02/19 08:58 AM
Posts: 12,233 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Must disagree on that. I have done it that way for many years. Carter mechanical pulls through a Holley electric. Has the OP blocked the exhaust cross over in the intake?
Master, again and still
[Re: DaveRS23]
#2672923
07/02/19 10:01 AM
07/02/19 10:01 AM
Posts: 668 Los Osos, Ca
CKessel
Los Osos, Ca
On the FBBO site, one of the posters found that the current fuel was boiling at 150*. Under hood and running temps are considerably higher.
Carl Kessel
[Re: TJP]
#2673323
07/02/19 06:35 PM
07/02/19 06:35 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Must disagree on that. I have done it that way for many years. Carter mechanical pulls through a Holley electric. I'll agree with Dave as I to have done the same. But be aware that the electric must be on when romping on it as it does cause a restriction that will result in a loss of fuel pressure / flow. Yep, I run a micro switch on the carb's secondaries to trigger the electric pump along with a manual switch under the dash..........just in case.
[Re: DaveRS23]
#2673340
07/02/19 07:23 PM
07/02/19 07:23 PM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
Had similar issues with AMC 360 4bbl and cast iron manifold. A phenolic carb spacer fixed the issue. Ordered it off summit.
[Re: gtx-guy]
#2677735
07/15/19 06:29 PM
07/15/19 06:29 PM
Posts: 357 The Garden State
LimelightCuda
The Garden State
Has anyone ever tried the Cool Carb stuff? Just wondering if it actually works.
Phil
1970 Barracuda Gran Coupe 1970 A66 Challenger Convertible
[Re: LimelightCuda]
#2677802
07/15/19 10:00 PM
07/15/19 10:00 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I have run the Cool Carb plate on my 340 for about five years or so. It does cool the carb! I have stopped the car in a parking lot, opened the hood to feel the carb to find it cool and sweating. It was strange. But it does get hot after a normal cool down process. But while driving, it seems to make a difference with the air passing around it. There is a max temp that CC specifies. Get your tuning correct and you should not have problems. I have had manifolds, iron J heads, aluminum heads, and headers on this engine and each time I pull the carb I make an effort to check the spacer plate. I have not had any problems but others will show pictures of the spacer plates melting. The owner is a nice guy and I would suggest to ask him what his max temp is and decide from his answer. He has a cool story on how he chose this material. 👍. If I remember correctly, it was used as a heat sinc material where he used to work.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
