Idle /Off Idle Problem PT Cruiser #2671917
06/30/19 12:40 PM
06/30/19 12:40 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
06 PT 82,000 miles.
Started as in park or neutral hot,it would chug/surge /miss then stall.
Drop it in gear,smooth..no issues.
Morphed into does it in gear also and lite throttle under 2 ,000rpm.
Does this about 30% of the time.
Ran codes ..no codes. But check engine light on.
Replaced, TPS....nope
Idle Motor. ...nope
Intake Temp sensor ...nope.
Plugs...nope.
Ideas, ,theories? ????
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Idle /Off Idle Problem PT Cruiser [Re: 6bblFLASH] #2671922
06/30/19 12:46 PM
06/30/19 12:46 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If your check engine light is on you have codes. If your code reader cannot display them I would suggest going somewhere else to see if they can read them. If not then you likely have an issue with your OBDII port not communicating. Fix that first
Re: Idle /Off Idle Problem PT Cruiser [Re: 6bblFLASH] #2671936
06/30/19 01:14 PM
06/30/19 01:14 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Where did you buy the sensors that you changed? Mopars don't like cheap auto parts store sensors.
Re: Idle /Off Idle Problem PT Cruiser [Re: 71birdJ68] #2671937
06/30/19 01:31 PM
06/30/19 01:31 PM
N.E. Ohio
N.E. Ohio
OEM off our other PT
Re: Idle /Off Idle Problem PT Cruiser [Re: 6bblFLASH] #2671995
06/30/19 04:44 PM
06/30/19 04:44 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Our 07 pt ran poorly and it turned out to be a burnt valve. It had about 70,000 miles on the clock. Somewhat common for those years.
Re: Idle /Off Idle Problem PT Cruiser [Re: mopars4ever] #2672121
06/30/19 09:14 PM
06/30/19 09:14 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Back to basics..compression test..
Check this also..
https://youtu.be/UxxrlLEPoEY
Re: Idle /Off Idle Problem PT Cruiser [Re: AARCONV] #2677007
07/13/19 09:52 AM
07/13/19 09:52 AM
N.E. Ohio
N.E. Ohio
Fixed.
Broken O2 wire.
Intake gasket leak.
