73 413 distributor #2671902
06/30/19 12:24 PM
06/30/19 12:24 PM
Ontario, Canada
GVH Offline OP
GVH  Offline OP
Ontario, Canada
Have a 1973 electronic distributor that came out a 413 motorhome ( industrial motor ). # on Dist. is 3656839 . Question is how well will it work in a RB . Know it will work ,MH had 4.56 gears .TIA
Re: 73 413 distributor [Re: GVH] #2671920
06/30/19 12:42 PM
06/30/19 12:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
If it checks good on the shaft to housing clearances I would shorten up the mechanical advance some (it will have a number stamp on the bottom of the advance plate scope which will be the amount of advance in distributor degrees so if it is stamp 12 it will have 24 crankshaft degrees at full advance) I like to have between 12 and 20 degrees at idle with no advance with 34 degrees max advance so use that and figure out what you want work
Measure the slot length and subtract the pin diameter to see how long the travel is and then divide the length by the degrees to get how much each degree is in thousands of a inch, if .300 long with 24 degrees that would be .0125 per degree wrench weld grin up
IHTHs
Re: 73 413 distributor [Re: Cab_Burge] #2672062
06/30/19 07:30 PM
06/30/19 07:30 PM
If the shaft/bushing (radial) side play is very minimal it'll be fine, as Cab said you can dial in the slots, you would set the initial/total/spring combo then plug in/adj the can (if used) IN ORDER. Speedway mtrs has a flat shim kit for $9.95 for the 1/2" dia dist lower shaft & reduce the axial play to .005"
Re: 73 413 distributor [Re: RapidRobert] #2672072
06/30/19 07:42 PM
06/30/19 07:42 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Check to see if that distributor is a DC/MP piece ..... I got two motors with that piece on them ... one with the wiring and the box up
Re: 73 413 distributor [Re: GVH] #2672101
06/30/19 08:43 PM
06/30/19 08:43 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
If it was a true industrial engine, it probably won’t work at all. Industrials used gear to gear cam timing. Reverse rotating cam requires odd distributor/ intermediate gear. Normal cam rotation drives the intermediate shaft down towards the bushing. Reverse rotation cam tries to drive the intermediate up towards the distributor. Those distributors are designed to hold the gear in position, and are not standard dimensions.
Re: 73 413 distributor [Re: TRENDZ] #2672104
06/30/19 08:47 PM
06/30/19 08:47 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
TRUE INDUSTRIAL... I don’t know but the ones I’ve seen in the motor homes is a diff distributor drive gear
Re: 73 413 distributor [Re: dOc …] #2672630
07/01/19 05:03 PM
07/01/19 05:03 PM
Ontario, Canada
GVH Offline OP
GVH  Offline OP
Ontario, Canada
looks like a reg. electronic distributor motor had the big water pump and different heads and big ex. manifolds one of which was broke
