Motor home trans #2671304
06/28/19 08:30 PM
06/28/19 08:30 PM
Ontario, Canada
GVH Offline OP
GVH  Offline OP
Ontario, Canada
See a MH TF at scrap yard I deal at .It is behind a 73 industrial 413 are there any good parts in it ? Has a short tail stock with large nut holding the yoke on ,rear is dana 60 /70 with 4.56 . front part of case has been damaged on the top . Are there any goodies .
Re: Motor home trans [Re: GVH] #2671309
06/28/19 08:44 PM
06/28/19 08:44 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
More than likely .... good front drum ... and 4 gear plantaires..... other regular steel parts. Should be cheap with a busted case
Re: Motor home trans [Re: dOc …] #2671319
06/28/19 09:11 PM
06/28/19 09:11 PM
A727Tflite Offline
A727Tflite  Offline
Pump to L/R drum is good to have, scrap the rest.
