eddy alum rpm heads with stock hp 440 manifolds #267068
03/26/09 09:55 AM
03/26/09 09:55 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline OP
does any one have this setup runing now,last night i switched the oe cast iron intake on my v-code super bee with an a-12 alum six pack intake to lighten it up. while the paint was dring, was thinking it would be cool with alum heads with stock manifolds. mocked up a manifold set to eddy rpm angle plug heads in the shop, driver side looks like it would work perfect, pass side is only close on #8,#6 plug to dump might grind pass manifold a bit? want to keep the manifolds on it,car is all oe except for wheels and radio
MOPAR OR NO CAR
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267069
03/26/09 10:36 AM
03/26/09 10:36 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I dont understand.....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: HemiRick] #267070
03/26/09 10:41 AM
03/26/09 10:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i barely understand ...
but yes you can do it , Andy F did it on a low deck stroker with E heads , made 570 HP ...
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: JohnRR] #267071
03/26/09 10:49 AM
03/26/09 10:49 AM
ok thats what im looking for someone has done it. manifolds will fit eddy heads just wondering what plugs /wires where used any other problems
MOPAR OR NO CAR
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267072
03/26/09 10:54 AM
03/26/09 10:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Why? you loose the benefit of the heads w/ the log mani's???
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: Mr.Yuck] #267073
03/26/09 11:05 AM
03/26/09 11:05 AM
well if a guy on here made 570 hp on a low deck,with eddys and manifolds how much can you be losing 40hp over headers it wont be much. i want to retain the stock look, not a race car, show car. im sure it will run better than tired, heavy 906s
MOPAR OR NO CAR
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267074
03/26/09 11:14 AM
03/26/09 11:14 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm guessing that is a heavily modified enigine. And the Main's were "hogged" out some. I don't think they up-grade on a stockish 440-6 would be the same. You'd probably add more HP by getting a set of headers.
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: Mr.Yuck] #267075
03/26/09 11:43 AM
03/26/09 11:43 AM
i bet its a tame street stoker 451-477 inch 10-5to1 comp pump gas. would be curious of his cam specs? heavily modified wedge to me is north of 700hp with no juice and and over 500 inches, we dont put manifolds on those
MOPAR OR NO CAR
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267076
03/26/09 11:48 AM
03/26/09 11:48 AM
I remember Andy's 440 buildup w 68-70 HP ex manifolds & 3" exhaust that netted 550 hp w alum heads. Dont recall if it was a stroker or the brand of the alum heads.
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267077
03/26/09 11:54 AM
03/26/09 11:54 AM
AndyF Online content
AndyF  Online Content
There are several articles in the tech archives on the subject. My low deck 470 worked great with HP manifolds and ported Edelbrock heads. You have to use the right cam though. I did a lot of cam testing and the MP .528 solid was better than any of the custom cams that were ground for that motor.
http://www.moparts.org/Tech/Archive/bigblock.html
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: AndyF] #267078
03/26/09 12:11 PM
03/26/09 12:11 PM
what do you think the most dur@50 you can have with 500 inch 440 with manifolds. my cam design so far is duration @ 50 int 246/250 ext solid flat tappet 555 intake lift 565 ext 112 lsa and icl 108, my motor plan 500 inch kit flat top pistons 10.59 comp with 88cc eddy heads. i want to put down over 500hp on rear wheel dyno
MOPAR OR NO CAR
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267079
03/26/09 01:14 PM
03/26/09 01:14 PM
That seems in the ballpark. You'll just have to try it and then go from there. I had a bunch of 475 rwhp pulls with that low deck 470 motor on the chassis dyno but that was about the limit.
Better head porting and more intake rocker ratio would have been the next items for me to try. If you're shooting for 500 rwhp you'll probably need to thrash the combination a bit. I'd suggest 1.6 or 1.7 rocker arms on the intake and 1.5 on the exhaust as one area to test.
Have the heads been modified? The CNC porting from Modern is a pretty good package. I think you'll need some good port work to hit your 500 rwhp goal.
I'd be very surprised if the 6 pack intake would support 500 rwhp, it really isn't a very good intake. Guess you'll find out. If you do back to back testing with the 6 pack vs. a Performer RPM I think you'll find some gains.
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: AndyF] #267080
03/26/09 01:28 PM
03/26/09 01:28 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
Use the MP version of the eddy's or stealths, they both have straight plugs that will give you more room around the manifolds.
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: Mr.Yuck] #267081
03/26/09 01:35 PM
03/26/09 01:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It was a 470" engine , nothing real exotic in the build, flat tappet cam, the manifolds were AS CAST ...
so you think a pair of headers is going to gain as much as changing from a set of heads that flow maybe 220 at .500 to a pair of heads that flow 280 plus at .500 ???
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: farmington] #267082
03/26/09 01:41 PM
03/26/09 01:41 PM
yes that would be easier but have eddys and 1.6 roller indy rockers. put a set of stealths on guys 512 thought the eddys where better but those angle plugs suck, had too ding in 2 tubes on my race car with hooker super comps
MOPAR OR NO CAR
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: JohnRR] #267083
03/26/09 01:48 PM
03/26/09 01:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Did something similar using Max Wedge exhaust manifolds on Eddys in my '63. Had to grind the bottoms of the manifolds a little to clear the head studs. The front of the right head is covered by the alternator, but the left head gives it away. For a more stock look, the 440Source heads would be better, but they weren't available when I did the car. It's nothing radical, but it makes plenty of power for the street.
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: hemigod426] #267084
03/26/09 01:56 PM
03/26/09 01:56 PM
I sold my 470 motor and built a 512 with CNC ported Mopar '452' heads. The 512 is finshed and has been on the dyno a few times but it isn't back in the car yet. One reason I switched heads was to go with a straight plug. The angled plugs on the Edelbrock heads worked with the HP manifolds but I had to keep a very close eye on the #6 boot. I made a little heat shield for it and that usually worked but you have to check it all the time.
My new 512 has a hyd roller cam in an attempt to make some more power. Same manifolds and Performer RPM intake. I'll also switch to a Holley 950 UltraHP in a search for some power. I was using the Edelbrock 800 cfm AFB and AVS carbs before. The Eddy carbs are great for a street/strip motor but they are down about 10 hp when compared to a modern HP style Holley carb.
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: JohnRR] #267085
03/26/09 01:58 PM
03/26/09 01:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think there are easier and cheaper ways to get HP than bolting on a set of Eddy heads. Especially if you are going to choke them up w/ a set of exhaust Mani's. Why not run the stock 2.25 exhaust while you're at it?
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: Mr.Yuck] #267086
03/26/09 02:12 PM
03/26/09 02:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes there are , but the person wants to use the parts he has , just like you want to use 440's and put holleys on them with headers ...it's all about CHOICE .
Re: eddy alum rpm heads with stock hp 440 manifolds [Re: JohnRR] #267087
03/26/09 02:19 PM
03/26/09 02:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I thought he wanted to BUY the heads and install them? Does he have the heads sitting on the shelf? Totally different thing...and I put 3 holleys on my lastest ride.
Coming soon!!!!
