eddy alum rpm heads with stock hp 440 manifolds
#267068
03/26/09 09:55 AM
03/26/09 09:55 AM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
does any one have this setup runing now,last night i switched the oe cast iron intake on my v-code super bee with an a-12 alum six pack intake to lighten it up. while the paint was dring, was thinking it would be cool with alum heads with stock manifolds. mocked up a manifold set to eddy rpm angle plug heads in the shop, driver side looks like it would work perfect, pass side is only close on #8,#6 plug to dump might grind pass manifold a bit? want to keep the manifolds on it,car is all oe except for wheels and radio
MOPAR OR NO CAR
Re: eddy alum rpm heads with stock hp 440 manifolds
[Re: HemiRick]
#267070
03/26/09 10:41 AM
03/26/09 10:41 AM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
I dont understand.....
i barely understand ...
but yes you can do it , Andy F did it on a low deck stroker with E heads , made 570 HP ...
[Re: Mr.Yuck]
#267073
03/26/09 11:05 AM
03/26/09 11:05 AM
hemigod426
well if a guy on here made 570 hp on a low deck,with eddys and manifolds how much can you be losing 40hp over headers it wont be much. i want to retain the stock look, not a race car, show car. im sure it will run better than tired, heavy 906s
MOPAR OR NO CAR
[Re: hemigod426]
#267074
03/26/09 11:14 AM
03/26/09 11:14 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I'm guessing that is a heavily modified enigine. And the Main's were "hogged" out some. I don't think they up-grade on a stockish 440-6 would be the same. You'd probably add more HP by getting a set of headers.
[Re: hemigod426]
#267076
03/26/09 11:48 AM
03/26/09 11:48 AM
RapidRobert
I remember Andy's 440 buildup w 68-70 HP ex manifolds & 3" exhaust that netted 550 hp w alum heads. Dont recall if it was a stroker or the brand of the alum heads.
[Re: hemigod426]
#267079
03/26/09 01:14 PM
03/26/09 01:14 PM
Posts: 30,995 Oregon
AndyF
That seems in the ballpark. You'll just have to try it and then go from there. I had a bunch of 475 rwhp pulls with that low deck 470 motor on the chassis dyno but that was about the limit.
Better head porting and more intake rocker ratio would have been the next items for me to try. If you're shooting for 500 rwhp you'll probably need to thrash the combination a bit. I'd suggest 1.6 or 1.7 rocker arms on the intake and 1.5 on the exhaust as one area to test.
Have the heads been modified? The CNC porting from Modern is a pretty good package. I think you'll need some good port work to hit your 500 rwhp goal.
I'd be very surprised if the 6 pack intake would support 500 rwhp, it really isn't a very good intake. Guess you'll find out. If you do back to back testing with the 6 pack vs. a Performer RPM I think you'll find some gains.
[Re: Mr.Yuck]
#267081
03/26/09 01:35 PM
03/26/09 01:35 PM
JohnRR
U.S.S.A.
It was a 470" engine , nothing real exotic in the build, flat tappet cam, the manifolds were AS CAST ...
so you think a pair of headers is going to gain as much as changing from a set of heads that flow maybe 220 at .500 to a pair of heads that flow 280 plus at .500 ???
[Re: JohnRR]
#267085
03/26/09 01:58 PM
03/26/09 01:58 PM
Mr.Yuck
Brookeville, Md
I think there are easier and cheaper ways to get HP than bolting on a set of Eddy heads. Especially if you are going to choke them up w/ a set of exhaust Mani's. Why not run the stock 2.25 exhaust while you're at it?
[Re: Mr.Yuck]
#267086
03/26/09 02:12 PM
03/26/09 02:12 PM
JohnRR
U.S.S.A.
Yes there are , but the person wants to use the parts he has , just like you want to use 440's and put holleys on them with headers ...it's all about CHOICE .
[Re: JohnRR]
#267087
03/26/09 02:19 PM
03/26/09 02:19 PM
Mr.Yuck
Brookeville, Md
I thought he wanted to BUY the heads and install them? Does he have the heads sitting on the shelf? Totally different thing...and I put 3 holleys on my lastest ride.
