Help, need front end height adjustment pec for 70 Challenger #2669064
06/23/19 03:58 PM
06/23/19 03:58 PM
Houston, Texas
FastOrange Offline OP
Houston, Texas
Performing front end alignment in my garage and I am unable to locate my factory repair manual.
Front end appears a little high. I measured 1.5 inches ride height. Installed Magnum force upper control arms. Thank you.
Re: Help, need front end height adjustment pec for 70 Challenger [Re: FastOrange] #2669066
06/23/19 04:04 PM
06/23/19 04:04 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
I just checked, it says 1 3/16" +/-1/8"
Hope this helps
Ken
Re: Help, need front end height adjustment pec for 70 Challenger [Re: FastOrange] #2669067
06/23/19 04:04 PM
06/23/19 04:04 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Factory manual in PDF, free download.
Re: Help, need front end height adjustment pec for 70 Challenger [Re: Sniper] #2669068
06/23/19 04:06 PM
06/23/19 04:06 PM
Houston, Texas
Houston, Texas
Thanks fellas
Re: Help, need front end height adjustment pec for 70 Challenger [Re: FastOrange] #2669110
06/23/19 06:41 PM
06/23/19 06:41 PM
I would suggest setting the ride height to where it looks good to YOU with the tire/wheel combo you have. bounce/jounce it & it may settle over time but you have your own alignment tools to recheck/reset as needed.
Re: Help, need front end height adjustment pec for 70 Challenger [Re: RapidRobert] #2669138
06/23/19 08:34 PM
06/23/19 08:34 PM
Houston, Texas
Houston, Texas
The ride height doesn't always settle into the same place after jouncing. So far I'm able to obtain about +4.5 caster with the Magnum Force upper A arms. I'm going to check alignment at different heights to dial it in. Thank you
Re: Help, need front end height adjustment pec for 70 Challenger [Re: FastOrange] #2669143
06/23/19 08:44 PM
06/23/19 08:44 PM
Houston, Texas
Houston, Texas
I have M/T P31560R15s on the back 30" tall and P2156515s 26" tall on the front. So I'm not sure exactly how having the larger back tires will affect alignment but I will be finding out soon. Thanks again
