Advice on cleaning a rusty MSD Distributor #2666047
06/14/19 11:35 PM
06/14/19 11:35 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Took apart my MSD distributor after see this. Can I salvage that magnetic pick up? Also what should I scrub the star and magnetic pick up with to remove the rust? Apply dialetic grease after?
I'm assuming that this is why my car is backfiring at 3k rpm and higher....
Thanks guys!
Re: Advice on cleaning a rusty MSD Distributor [Re: WS68SSC] #2666058
06/15/19 12:11 AM
06/15/19 12:11 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Sad that an MSD looks like that after 2 years!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Advice on cleaning a rusty MSD Distributor [Re: hemi-itis] #2666060
06/15/19 12:23 AM
06/15/19 12:23 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
That’s not the distributors fault.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Advice on cleaning a rusty MSD Distributor [Re: pittsburghracer] #2666067
06/15/19 12:55 AM
06/15/19 12:55 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Emory cloth
Re: Advice on cleaning a rusty MSD Distributor [Re: WS68SSC] #2666075
06/15/19 01:53 AM
06/15/19 01:53 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I'm still running a 20 year old one that looked way worse than that. The wheel looked like a sea urchin. I cleaned it up with some rust penetrant and bolted it back in the car. I would check your plug gap for the back/misfire situation. If you are running the #8261 HVC-II coil gap at .025.
Re: Advice on cleaning a rusty MSD Distributor [Re: WS68SSC] #2666085
06/15/19 04:30 AM
06/15/19 04:30 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
MSD doesn't properly coat any of the internal parts. I've cleaned and coated the ferrous parts with a rust converting spray that turned them black. I also drilled a couple large holes in my cap, and made sure the rotor was properly phased, which required an expensive adjustable rotor turned to nearly full travel to correct the phasing issue.
The venting and phase alignment helps reduce the ozone issue mentioned in the post directly below this.
Re: Advice on cleaning a rusty MSD Distributor [Re: jbc426] #2666098
06/15/19 07:46 AM
06/15/19 07:46 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Pretty much the norm for MSD or any distributor for that matter, Oxygen is ionized into ozone by the high voltages and ozone is highly corrosive. I just keep mine oiled and squirt some rust inhibitor in there from time to time.
Re: Advice on cleaning a rusty MSD Distributor [Re: Tig] #2666110
06/15/19 08:46 AM
06/15/19 08:46 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You can wire wheel those parts with a Dremel. I like the idea of the coating. More info? An adjustable rotor for proper phasing is one way, or just make your own locating tab in the spot you need it after you dial it in.
Rust is caused by moisture in the air. By the time I was close to finishing my chassis, surface rust was working its way across the earlier installed bars. If it's a drag car or weekend beater, maybe removing the cap and throwing a towel over the distributor would be a good practice. I have also seen that from engine vapors backing up through the shaft if there is no pcv system on a street car.
Re: Advice on cleaning a rusty MSD Distributor [Re: sgcuda] #2666200
06/15/19 02:23 PM
06/15/19 02:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Glass bead, small wire brush, maybe easier and cheaper to just throw new parts in it, including a pick up. Vent the cap. Hit it all with WD40 once in a while.
Re: Advice on cleaning a rusty MSD Distributor [Re: CMcAllister] #2666312
06/15/19 08:12 PM
06/15/19 08:12 PM
CA
crackedback Offline
crackedback  Offline
CA
Brass brush. I wipe them with a little bit of PB blaster on a rag.
I clean them and coat em as well. Just cheap [censored] stuff from MSD for not treating the materials properly for the job they will do.
Re: Advice on cleaning a rusty MSD Distributor [Re: crackedback] #2666351
06/15/19 11:48 PM
06/15/19 11:48 PM
hemi-itis Offline
hemi-itis  Offline
That add a buck to the price! twocents
Re: Advice on cleaning a rusty MSD Distributor [Re: hemi-itis] #2666420
06/16/19 09:38 AM
06/16/19 09:38 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
This post reminds me that I need to clean the reluctor in my MSD distributor. My spare shows no sign of rust but it has what looks like some kind of coating. I think it's the one in the link below.
https://www.amazon.com/MSD-8627-Distributor-Reluctor/dp/B001GA82QW
Re: Advice on cleaning a rusty MSD Distributor [Re: justinp61] #2666437
06/16/19 10:09 AM
06/16/19 10:09 AM
moparx Offline
moparx  Offline
that looks like your basic zinc plating that comes on your hardware store bolts.
it is rather comical that amazon lists the pickup as a commonly bought item with the reluctor. laugh2
beer
Re: Advice on cleaning a rusty MSD Distributor [Re: moparx] #2666537
06/16/19 02:52 PM
06/16/19 02:52 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Not really sure what caused that. This one had been sitting on my workbench for over 10 years, recently found cleaning...
Re: Advice on cleaning a rusty MSD Distributor [Re: crackedback] #2667064
06/18/19 01:07 AM
06/18/19 01:07 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
This is one of my MSD distributors out of my cigarette boat with twin 588 cu in BBC. I completely wire brushed the rust and cleaned both dizzy's about 9 months before this pic was taken.... i shot the insides with some CRC spray and this is what they both looked like when I pulled them out 9 months later, about the same as before I cleaned them up originally. It is a well known problem with MSD and boats, even though no water or spray gets in the bilge area.
I called MSD tech to see if they still rebuild them, and since they have been sold, they do not offer this anymore. I told the tech it was a marine application that requires Coast Guard certified regulations for spark control in case of bilge fumes etc...... and he told me the best thing to do would be to drill huge holes in the cap to let ionized air out to see if that helps panic realcrazy
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Advice on cleaning a rusty MSD Distributor [Re: Rapid588] #2667071
06/18/19 01:37 AM
06/18/19 01:37 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
I again disassembled them, wire brushed the steel parts to bare metal, and shot each component, including the weights (which had been rusted solid on the shaft) with a light coat of epoxy PPG primer that I was using for something else at the time.
I had some 2 part Sharkhide (brand) acid cleaner and sealer that I also had laying around that I used for the the aluminum distributor body as it also had badly corroded, then I assembled with new magnetic pickup, rotor, and the correct marine distributor cap that does NOT have the small black vent cap on top like the regular automotive ones have (coast guard regs.... no vent/spark hazard from a vented cap).
I also sprayed inside a very light mist of Gibbs Spray on everything including the reluctors and pickups before closing it up
I just took dizzy's out a couple weeks ago after running them again for about 8 months to redo some intake gaskets and this is how they still look.... I was kinda shocked as there is minimal corrosion after doing these simple mods. (the rough aluminum look is from the previous corrosion).
My theory, at least on a marine application, even though there is no water or spray mist getting in the bilges, when the hot engines are shut off after a day of use.... including running them with fresh water for 15 minutes to flush, as the distributors cool off they are sucking humid air in as they cool down, which is causing the massive rusting problems.
I think that by this coating of all the inside components (there is minimal or no coating from MSD on these components whatsover) and possibly by NOT using the vented type caps (some air does still come in through cap edges i am sure) I think I found a solution of the corrosion/rusting that most ALL marine MSD users face......
I originally did a search how to combat this, and found TONS of automotive users were complaining of the same rusting issues on their MSD's
Re: Advice on cleaning a rusty MSD Distributor [Re: Rapid588] #2667087
06/18/19 05:50 AM
06/18/19 05:50 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Have the same problem on mine in a street application. Drilled holes in the cap but still corrodes pretty fast.
Re: Advice on cleaning a rusty MSD Distributor [Re: WS68SSC] #2667097
06/18/19 07:47 AM
06/18/19 07:47 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
You do know that those parts, the pick up coil and reluctor are ford parts don't you?? parts store stuff
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Advice on cleaning a rusty MSD Distributor [Re: yella71] #2667112
06/18/19 08:39 AM
06/18/19 08:39 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here's the part that I question. Why dont other brand manufactuars distributors have this issue? My 440 source looks like new after 7 years of use. Never had an issue with factory units either. Why?
Doug
Re: Advice on cleaning a rusty MSD Distributor [Re: dvw] #2667149
06/18/19 10:55 AM
06/18/19 10:55 AM
moparx Offline
moparx  Offline
good question about the "other" distributors doug. if i ever go with an MSD distributor, i will be coating everything inside with epoxy of some sort before installation.
beer
