Page 1 of 5 1 2 3 4 5
420 going on the dyno updated 6-30-20 #2665619
06/13/19 08:12 PM
06/13/19 08:12 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
OK who wants to take a guess at what this thing will make.
420 CI
4.065 bore
4.050 stroke
13.5:1 comp
Thitek heads 2.18 intake valve flow 390 at 650
Bullet cam 645 640 260 266 on a 110
Ritter low rise intake
1000 HP holley
Milodon oil system
on C12 fuel
Re: 420 going on the dyno next couple days [Re: biff426] #2665665
06/13/19 10:03 PM
06/13/19 10:03 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
That should be on the +700hp for sure.....I wil go out on a limb and say 740hp...
Re: 420 going on the dyno next couple days [Re: Dragula] #2665746
06/14/19 09:16 AM
06/14/19 09:16 AM
IL
Dart451 Offline
Dart451  Offline
IL
i will see your 740hp and raise to 777hp beer
Who doesn't want a triple seven.
Re: 420 going on the dyno next couple days [Re: Dart451] #2665772
06/14/19 10:21 AM
06/14/19 10:21 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I say 755 hp. Please let us know and get video!
Re: 420 going on the dyno next couple days [Re: fbs63] #2666633
06/16/19 07:41 PM
06/16/19 07:41 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
My guess is "more with 3" plenum spacer"
Re: 420 going on the dyno next couple days [Re: sixpackgut] #2666714
06/17/19 12:10 AM
06/17/19 12:10 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Should be making pulls tomorrow or Tuesday Fired it Friday and ran out of time. Guy that owns the dyno was busy this weekend. Thing sounds wicked!!! Making some base pulls then first thing to do is add a 2 inch spacer......although I don't have the hood clearance for it I want to see what it does.
Re: 420 going on the dyno next couple days [Re: biff426] #2666740
06/17/19 07:43 AM
06/17/19 07:43 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Where do you have timing and do you plan on moving your timing around?
Re: 420 going on the dyno next couple days [Re: sixpackgut] #2666741
06/17/19 07:57 AM
06/17/19 07:57 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
My 426 makes best power at 22 have it at 20 now to start will fool around from there,
Re: 420 going on the dyno next couple days [Re: biff426] #2667066
06/18/19 01:10 AM
06/18/19 01:10 AM
SoCal
Brian Hafliger Offline
SoCal
735HP and 575TQ....
Brian Hafliger
Re: 420 going on the dyno next couple days [Re: biff426] #2667187
06/18/19 01:10 PM
06/18/19 01:10 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'm a Gen III Dummy, but am looking forward to your results.
Also, where is the engine being tested, and on what type of engine dyno?
Re: 420 going on the dyno next couple days [Re: BradH] #2667298
06/18/19 05:29 PM
06/18/19 05:29 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
popcorn
Re: 420 going on the dyno next couple days [Re: cudadoug] #2667310
06/18/19 06:12 PM
06/18/19 06:12 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Fighting a water leak in the front cover motor plate deal. Got it fixed now, pulls in the morning.
Re: 420 going on the dyno next couple days [Re: BradH] #2667330
06/18/19 07:08 PM
06/18/19 07:08 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
It is a Stuska dyno
Re: 420 going on the dyno next couple days [Re: biff426] #2667441
06/19/19 06:20 AM
06/19/19 06:20 AM
Australia
aus370 Offline
aus370  Offline
Australia
765 hp
Re: 420 going on the dyno next couple days [Re: biff426] #2667647
06/19/19 04:48 PM
06/19/19 04:48 PM
BradH Offline
BradH  Offline
It is a Stuska dyno
At what shop? PA, MD, DE, NJ?
Re: 420 going on the dyno next couple days [Re: BradH] #2667917
06/20/19 11:31 AM
06/20/19 11:31 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
It is a Stuska dyno
Georgetown, DE Performance injection equipment
Re: 420 going on the dyno next couple days [Re: biff426] #2667926
06/20/19 11:39 AM
06/20/19 11:39 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
SO made a couple hits with the 850 dyno carb and timing from 20-26 degrees it liked 22 made 748HP.@7300. Putting the bigger carb and spacers on it and going to play with jetting should be worth some HP. ALso the headers we had to use are 13/4 and the ones going in the car are 2" not sure what if anything that will do. Can't get the 2" to fit on the dyno without reinventing the wheel.
Re: 420 going on the dyno next couple days [Re: biff426] #2667933
06/20/19 11:43 AM
06/20/19 11:43 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
What kind of car is this going in? I can't wait to see track times especially from an East coast track.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 420 going on the dyno next couple days [Re: biff426] #2667945
06/20/19 11:55 AM
06/20/19 11:55 AM
BradH Offline
BradH  Offline
Nice, but I think there's more in it. I'll take a s.w.a.g. that the 1.75" headers are costing you about 20 HP over a good set of 2" tubes.
Yep, I know where G-town DE is, but haven't been through it in years. My trips from NoVA in that direction tend to go south (OC) or north (NJ) of there.
Re: 420 going on the dyno next couple days [Re: biff426] #2667976
06/20/19 01:07 PM
06/20/19 01:07 PM
IL
Dart451 Offline
Dart451  Offline
IL
Making some steam!! keep updates coming
