REAR VIEW MIRROR FALLING #2665485
06/13/19 12:44 PM
06/13/19 12:44 PM
Amherst
P
plumcrzyTA Offline OP
P
Amherst
I have a 71 demon and the rear view mirror keeps falling down.Is there anyway to keep it from sliding around? THANKS!!! David
Re: REAR VIEW MIRROR FALLING [Re: plumcrzyTA] #2665486
06/13/19 12:47 PM
06/13/19 12:47 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
There should be three screws that hold the assembly to the roof. Once you have the mirror in your hand, you'll see a couple screws on the top side that hold a metal plate over the "ball" on top. Those screws could be a little loose or the threads could be messed up. You might be able to slightly bend the metal plate a little to put more pressure on the "ball".
Re: REAR VIEW MIRROR FALLING [Re: burdar] #2665492
06/13/19 12:54 PM
06/13/19 12:54 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Ditto. I took mine apart and slightly bent the metal plate. All was good afterwards.
Re: REAR VIEW MIRROR FALLING [Re: Reggie] #2665573
06/13/19 04:58 PM
06/13/19 04:58 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Relatively an easy fix. iagree
Re: REAR VIEW MIRROR FALLING [Re: 5carguy] #2665692
06/14/19 12:25 AM
06/14/19 12:25 AM
Maryland
MoparMike1974 Offline
Maryland
Back in the day I would fix these by putting a small piece of tin foil between the plate and the ball.
Re: REAR VIEW MIRROR FALLING [Re: MoparMike1974] #2665790
06/14/19 11:45 AM
06/14/19 11:45 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
He didn't indicate which adjuster was loose, The top one or the one on the back of the mirror. if the mirror is "falling" I would think it's the one on the back confused whistling beer
Re: REAR VIEW MIRROR FALLING [Re: TJP] #2665807
06/14/19 12:04 PM
06/14/19 12:04 PM
moparx Offline
moparx  Offline
it all comes down to "the angle of the dangle" [biggrin]
depending on how the pieces are angled for the driver to see, it could be either piece that is loose.
it possibly could be the mirror head pivot, but most times, it's the stem that bolts to the roof, and you can tighten that up.
hopefully, the OP will report back and clarify.
beer
Re: REAR VIEW MIRROR FALLING [Re: moparx] #2665812
06/14/19 12:22 PM
06/14/19 12:22 PM
BDW Offline
BDW  Offline
Tightening the screws didn’t work for me, removed the retainer, laid it flat on concrete and gave it a couple taps with a hammer to close up the seat area.
