Where to connect 68 B Body Console Wiring #266470
03/25/09 08:59 PM
03/25/09 08:59 PM
Louisiana
duckblind Offline OP
Louisiana
I am converting a 68 charger from auto on the column to auto on the floor. I just got the short wiring harness for the console and the longer harness that I was told goes behind the drivers seat and then up to the kick panel. Does any one know what this is supposed to plug in to? My wiring diagram only says that it goes to the instrument panel. It is a 4 prong sort of connector along with a single connector and the ground. Thanks
Re: Where to connect 68 B Body Console Wiring [Re: duckblind] #266471
03/25/09 10:27 PM
03/25/09 10:27 PM
Indiana USA
DBishop68 Offline
DBishop68  Offline
Indiana USA
You need 68 only under dash console wiring, its a option/add on harness.2 feeds that stack in fuse box 2 from the normal column shift plugs, down to the kick panel 66-7 69 70 not the same.I have one for sale.
