Hemi 6 on eagle engine. #2662652
06/05/19 01:28 PM
06/05/19 01:28 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Just checking and the cam timing sprocket on an early 5.7 is the same as the 5.7 eagle.
Spacing for the pickup.
Now if i change the reluctor wheel for a 32 tooth one and lock the phaser, could i use the Hemi6 and a carb on an eagle engine?
Matt
Re: Hemi 6 on eagle engine. [Re: MattW] #2663103
06/06/19 02:46 PM
06/06/19 02:46 PM
Texas
0
03heavy Offline
03heavy  Offline
Texas
From what I’ve been able to find it should work
I have to mount my 6.4 vvt to engine run stand and see if it will run
At this point I have swapped the reluctor wheel for the 32th tooth
Also the crank and cam sensor for the older style
And locked the vvt
I used the msd harness for the 09 and up cool packs
I should know if it will run in a few weeks
Re: Hemi 6 on eagle engine. [Re: 03heavy] #2663452
06/07/19 11:46 AM
06/07/19 11:46 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
And locked the vvt
Exactly what I plan on doing.
Post some pics of your break in stand please.
Re: Hemi 6 on eagle engine. [Re: MattW] #2663544
06/07/19 04:14 PM
06/07/19 04:14 PM
Texas
0
03heavy Offline
03heavy  Offline
Texas
I’m having trouble posting pictures on the website
Never been able to
I dunno why
Re: Hemi 6 on eagle engine. [Re: 03heavy] #2663591
06/07/19 06:37 PM
06/07/19 06:37 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Most likely your camera setting are to big. Something to do with quality of the picture.
My Samson S7 works easier than posting them from my computer.
Matt
Re: Hemi 6 on eagle engine. [Re: MattW] #2663698
06/08/19 04:11 AM
06/08/19 04:11 AM
Australia
L4staero Offline
L4staero  Offline
Australia
What is making guys not want to just use the factory injection systems
Re: Hemi 6 on eagle engine. [Re: L4staero] #2663734
06/08/19 09:25 AM
06/08/19 09:25 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Cuz i have everything i need right now. Going that route is more money.
Re: Hemi 6 on eagle engine. [Re: MattW] #2663862
06/08/19 10:00 PM
06/08/19 10:00 PM
Australia
L4staero Offline
L4staero  Offline
Australia
If there was a solution to make running fuel injection cheaper would people go for it?
Given that most junk yard engines come with intake manifold with injectors etc it doesnt take much to get them to run.
Going the carb route you have to buy the MSD ign kit, a carb intake and a carb. I presume to go out and buy that stuff would cost like $1000.
I had a comlete 6.4 crate engine and needed a way to run it.
I picked up a 6.4 engine and body harness, pedal, PCM on ebay for $120.
I have less than $100 of connectors, relays and terminals and a few hrs into modding the factory engine harness and making a compatible body harness to make the whole lot run standalone. Just need the PCM reflashed to run stand alone and will be all good to go for around the $300 mark.
A bit off topic but just putting it out there
Re: Hemi 6 on eagle engine. [Re: L4staero] #2664704
06/11/19 10:27 AM
06/11/19 10:27 AM
Texas
0
03heavy Offline
03heavy  Offline
Texas
For what I. Doing the carb is perfect
I don’t get why it’s an issue
I’ve been index/ grudge racing my car for a very long time
With a high compression e85 setup with the LA platform
Decided to more into the 3rd gen deal
And basically have to use intake and a ignition controller
Then back in business
I have a ton of money in e85 fuel system
Also slow a carb down is not that hard
I know every says says to just pull timing with injection and it will slow
It’s not that easy I’m far from a pro but I’ve been around
Re: Hemi 6 on eagle engine. [Re: 03heavy] #2664705
06/11/19 10:28 AM
06/11/19 10:28 AM
Texas
0
03heavy Offline
03heavy  Offline
Texas
Wrong picture
But cool it worked thanks
These engine can/should be used in any enthusiast’s
Needs
different applications will only bring more of a aftermarket
Following
Not everyone has the same goals
And don’t t think I’m a efi hater
I’ll be using the factory efi in my D300
