Convertible top pump rebuild #2664213
06/10/19 12:00 AM
06/10/19 12:00 AM
Seattle WA
RichV Offline OP
RichV  Offline OP
Seattle WA
It looks like I need to rebuild my convertible top pump. Any advice on the rebuild or a source for a good quality rebuild kit? I found a universal kit on Fleabay, no idea about the quality of it, is there another better source?
Re: Convertible top pump rebuild [Re: RichV] #2664236
06/10/19 02:56 AM
06/10/19 02:56 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I'm assuming you have a pump that runs, but just doesn't move/pump fluid, then yes should be easy, I've not done this.....but see no reason it should be hard.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Convertible top pump rebuild [Re: HemiRick] #2664248
06/10/19 06:12 AM
06/10/19 06:12 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Here is a link to a rebuild of a GM pump unit, maybe similar to get you going.
http://autobodystore.com/forum/show...e-Top-pump-motor-disassembly-and-rebuild
Re: Convertible top pump rebuild [Re: larry4406] #2664384
06/10/19 01:05 PM
06/10/19 01:05 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I took my 68 pump apart and put the E-bay seal kit in it. Here is a link to my pictures I posted on FABO. It's super simple to disassemble. After I got mine done, I heard that they used the same pump for years. Even a pump from a 90's LeBarron will work. Depending on the condition of yours, you might be able to find a good replacement really cheap compared to buying a rebuilt unit.
https://www.forabodiesonly.com/mopar/ams/convertible-top-pump-disassembly.157/
Re: Convertible top pump rebuild [Re: burdar] #2666739
06/17/19 07:29 AM
06/17/19 07:29 AM
London, England
Gavin Offline
Gavin  Offline
London, England
I also rebuilt my Challenger pump, got the kit from Hydro-e-lectric who also sell cylinders, hoses etc. I had one question and they answered it quickly and efficiently. I agree it's pretty straightforward to do. I plumbed mine back in and it all works as it should. My only issue is a small weep which I have yet to diagnose. I'm guessing it's the reservoir O-ring, maybe it's not quite tight enough (or too tight...?) which I was planning to ask them about....
