Re: 440 cast or steel crank
[Re: wvmarv]
#2664031
06/09/19 01:46 PM
06/09/19 01:46 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
If the motor is stock and has never had any work done on it then you can look on the side of the block for the casting date, if it was cast after 08-30-73 it will be a 1974 motor and it should have a cast crankshaft with the oddball looking front balancer that says for cast crankshafts only Mopar used forged steel crankshafts in some of the 1973 440 motor home motors and some cast crankshafts. The word is that Mopar switch to cast crankshafts in all the passenger car motors in 1972 or 1973, not truly so on the BB stick shift pickup truck motors What are your concerns on wanting to know about this?
[Re: wvmarv]
#2664079
06/09/19 04:46 PM
06/09/19 04:46 PM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
thin dampener... forged thick dampener... cast ( on this pic the thick one is very lates cast called "bullet" kind, but earliers cast pieces are straight about same thickness on TC unweightened TC forged weighted TC, cast
[Re: NachoRT74]
#2664098
06/09/19 05:23 PM
06/09/19 05:23 PM
RapidRobert
As said the dampener should tell you but worse case you could run a borescope up in the oil pan drain hole & directly eyeball the crank parting lines.
[Re: wvmarv]
#2664137
06/09/19 07:42 PM
06/09/19 07:42 PM
Posts: 4,694 Wichita
GY3
Wichita
If it breaks above 600 hp, it's a cast crank. LOL
[Re: GY3]
#2664143
06/09/19 08:05 PM
06/09/19 08:05 PM
RapidRobert
^^^ Ding ding ding I (do) believe we have a winna
