440 cast or steel crank #2664014
06/09/19 12:43 PM
06/09/19 12:43 PM
WV,USA
W
wvmarv Offline OP
wvmarv  Offline OP
W
WV,USA
I need to know how to tell if the crankshaft in my 440 is cast or steel while it's still in the car? Thanks for the help.
Re: 440 cast or steel crank [Re: wvmarv] #2664031
06/09/19 01:46 PM
06/09/19 01:46 PM
If the motor is stock and has never had any work done on it then you can look on the side of the block for the casting date, if it was cast after 08-30-73 it will be a 1974 motor and it should have a cast crankshaft with the oddball looking front balancer that says for cast crankshafts only scope
Mopar used forged steel crankshafts in some of the 1973 440 motor home motors and some cast crankshafts.
The word is that Mopar switch to cast crankshafts in all the passenger car motors in 1972 or 1973, not truly so on the BB stick shift pickup truck motors confused shruggy
What are your concerns on wanting to know about this?
Re: 440 cast or steel crank [Re: Cab_Burge] #2664043
06/09/19 02:11 PM
06/09/19 02:11 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Forged crank has a thick parting line. Cast cranks have a sharp parting line.
Sheldon
Re: 440 cast or steel crank [Re: wvmarv] #2664079
06/09/19 04:46 PM
06/09/19 04:46 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
thin dampener... forged
thick dampener... cast
( on this pic the thick one is very lates cast called "bullet" kind, but earliers cast pieces are straight about same thickness
on TC
unweightened TC forged
weighted TC, cast
Re: 440 cast or steel crank [Re: NachoRT74] #2664098
06/09/19 05:23 PM
06/09/19 05:23 PM
As said the dampener should tell you but worse case you could run a borescope up in the oil pan drain hole & directly eyeball the crank parting lines.
Re: 440 cast or steel crank [Re: Cab_Burge] #2664103
06/09/19 06:00 PM
06/09/19 06:00 PM
WV,USA
W
wvmarv Offline OP
wvmarv  Offline OP
W
WV,USA
I'm going to do a 4-speed conversion and need to know which crank is in the engine before I order the kit. The engine was in the car when I bought it. It is not the original engine.Thanks for the info.
Re: 440 cast or steel crank [Re: NachoRT74] #2664104
06/09/19 06:02 PM
06/09/19 06:02 PM
WV,USA
W
wvmarv Offline OP
wvmarv  Offline OP
W
WV,USA
Thanks a ton, I will eyeball the dampener.
Re: 440 cast or steel crank [Re: RapidRobert] #2664105
06/09/19 06:05 PM
06/09/19 06:05 PM
WV,USA
W
wvmarv Offline OP
wvmarv  Offline OP
W
WV,USA
Great idea. Thanks
Re: 440 cast or steel crank [Re: RUNCHARGER] #2664106
06/09/19 06:08 PM
06/09/19 06:08 PM
WV,USA
W
wvmarv Offline OP
wvmarv  Offline OP
W
WV,USA
Thanks, I knew to check that when the crank was out of the engine, but this engine is still in the car.
Re: 440 cast or steel crank [Re: wvmarv] #2664137
06/09/19 07:42 PM
06/09/19 07:42 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
If it breaks above 600 hp, it's a cast crank. LOL
'63 Dodge 330
11.19 @ 121 mph
Re: 440 cast or steel crank [Re: GY3] #2664143
06/09/19 08:05 PM
06/09/19 08:05 PM
^^^ Ding ding ding I (do) believe we have a winna
Re: 440 cast or steel crank [Re: wvmarv] #2664165
06/09/19 09:09 PM
06/09/19 09:09 PM
You should make absolutely sure the flywheel and balancer are match for the motors type of balancing scope
I bought a 1976 400 short block out of a 1976 dodge 3/4 ton pickup, it had a forged steel crank and a thin balancer work confused
I didn't get to see the flywheel so I'm not sure if that motor was internally balanced or not shruggy The balancer had a bunch of holes drill in the back side of the outer ring, all on one side confused work
