Cam identification #2663843
06/08/19 07:45 PM
06/08/19 07:45 PM
Minnesota
TrackPack Offline OP
Minnesota
This three bolt cam was given to me many years ago. Came in Lunati box with no cam card. Anyone have any ideas from the numbers?
Re: Cam identification [Re: TrackPack] #2663939
06/09/19 08:14 AM
06/09/19 08:14 AM
A727Tflite Offline
A727Tflite  Offline
May be a long shot but back in the 70’s the Stock Eliminator 440-6 cam was referred to as a “980” cam.
Fastramp cheater cam with lots of duration.
Check the lift on it - if around .455” intake and .470” exhaust then real good possibility it’s one of those.
Looking at the nose of those lobes it looks like one of them.
Re: Cam identification [Re: TrackPack] #2663964
06/09/19 09:35 AM
06/09/19 09:35 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Have you contacted Lunati to see if they can/will help?
It's Swifty! Swifty, you toad sucker!
Re: Cam identification [Re: A727Tflite] #2663986
06/09/19 10:43 AM
06/09/19 10:43 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The lobes do have the stocker look to them.
Re: Cam identification [Re: fast68plymouth] #2664068
06/09/19 04:16 PM
06/09/19 04:16 PM
Minnesota
Minnesota
That's a great idea. I'll check the lift, if it turns out to be .455/.470 most likely a class legal cam. Wouldn't be many other reasons to limit it to that specific lift. Thanks for the replies.
Re: Cam identification [Re: zrxkawboy] #2664144
06/09/19 08:07 PM
06/09/19 08:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
whistling beer
Re: Cam identification [Re: zrxkawboy] #2664707
06/11/19 10:35 AM
06/11/19 10:35 AM
Minnesota
Minnesota
No reply from Lunati to email sent Monday........waiting
Re: Cam identification [Re: TrackPack] #2719598
11/26/19 11:39 PM
11/26/19 11:39 PM
A727Tflite Offline
A727Tflite  Offline
Ever determine what cam this was ?
Re: Cam identification [Re: A727Tflite] #2719816
11/27/19 05:32 PM
11/27/19 05:32 PM
Minnesota
Minnesota
Not yet. I have a block almost ready to mock up, but back burner for a little while longer.
