68 road runner emblem placement #2663269
06/06/19 09:24 PM
06/06/19 09:24 PM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
Does someone have the measurements for the side and deck lid road runner emblems and bird locations for a non deluxe model? Are they found in the 68 shop manuals or cd?
2CEFFB26-AFA5-4D0B-96AB-1D59A7DC0D85.pngF7BFC7AC-10EB-4875-83B7-745673564AA9.pngE6B2DFAC-E0AE-483D-9A12-1A40525C1DCE.pngFDF75272-B3A1-4FEB-AD2C-967A290B1EA0.png
Re: 68 road runner emblem placement [Re: Airgrabber] #2663473
06/07/19 12:34 PM
06/07/19 12:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Well, the nameplates are located by the holes for them that are punched in the panels, so I'm guessing you're dealing with replacement sheet metal?
I've got a base 383 coupe in the shop I can measure later.
Or you can Google it if you're in a bind for time.
Re: 68 road runner emblem placement [Re: Airgrabber] #2663582
06/07/19 06:03 PM
06/07/19 06:03 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I have a bunch of photos with a measuring tape and some with lines and dimensions but they all need to be resized and sorry at this moment I could only get to the right trunk lid bird. If I get a chance later tonight I'll try and post what I have......but resized.
Mike
Oops, thought there was something wrong with my before restoration documentation............................and even after the resto I'm still off by a 1/4" on the emblem inboard from the trunk lid edge. blush I have more but they are probably off also frown
Re: 68 road runner emblem placement [Re: A12] #2663616
06/07/19 08:11 PM
06/07/19 08:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Measured mine, measurements are to the nameplates & birds once installed, but you should be able to work backwards to get locations for mounting holes.
Door emblems - 3 3/8" from ft door edge to edge of nameplate, also 3 3/8" from top of door contour to top of nameplate.
Door birds - 2 1/2" from top door contour to top of bird, bird is about centered vs nameplate, 1/4" from rear of nameplate to bird. Birds are running toward front of car.
Trunklid - RR nameplate 1/4" above middle contour of lid to bottom of nameplate, 2 1/4" from rt edge of lid to rt edge of nameplate.
Trunk bird is standing, not running, centered above RR nameplate with a 3/8" gap.
"Plymouth" nameplate is 1" above center contour to bottom of letters, 7 1/4" from rt edge of lid.
"Hemi" nameplate was on the left side but I don't have those measurements handy, sold that car a couple years ago but will post a photo.
Dash nameplate 5" from A-pillar trim to rt edge of nameplate, 1 1/4" from top of glovebox door to bottom of nameplate.
Dash bird is standing type, 3/8" gap to nameplate, centered heightwise off the nameplate.
Re: 68 road runner emblem placement [Re: topside] #2663642
06/07/19 09:50 PM
06/07/19 09:50 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
These are measurements from my RR. I'll have to dig around for the door decal numbers.
