E body Oil pressure sending unit wire
#2663099
06/06/19 02:28 PM
06/06/19 02:28 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
Does anybody know where to find a replacement wire for the one that slides on the tab on top of the oil pressure sending unit for and E body? I put a brand new engine harness in the car and the gray wire from the bulkhead connector for the oil pressure sender is only a few inches long with a female bullet style connector on it. Does anybody sell the short piece with the male bullet connector and the terminal end that slides onto the oil pressure sender? I cant seem to find anything. Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: E body Oil pressure sending unit wire
[Re: 71birdJ68]
#2663154
06/06/19 05:52 PM
06/06/19 05:52 PM
Posts: 2,384 White Plains, NY
VCODE
White Plains, NY
Call Frank Baldason, he might have something I'am sure he has the terminal end. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: a12rag]
#2663261
06/06/19 09:10 PM
06/06/19 09:10 PM
73cuda340
clarks summit pa
Could always make your own ??? . . . . a piece of wire, correct connectors on each end . . . voila . . . I planned on making my own originally. I have the bullet connectors but I cant seem to find the connector that goes on the sending unit. Thanks for the pictures
[Re: gzig5]
#2663264
06/06/19 09:12 PM
06/06/19 09:12 PM
73cuda340
clarks summit pa
I should be putting a new M&H harness in sometime in the next couple weeks. If you can wait, I'll send you my old one. I think it has about 5" of wire from the connector where someone spliced it. Ok thanks. Ill see if I can find anything first, if not I'll let you know. Im not in a big hurry, I'm having a bunch of issues with my new motor, so unfortunately there's going to be some downtime.
