Steel Hemi Block Conversion #2662791
06/05/19 07:23 PM
06/05/19 07:23 PM
camaroduster Offline OP
Can a steel Hemi Block be converted to use BB Wedge Heads?
Re: Steel Hemi Block Conversion [Re: camaroduster] #2662808
06/05/19 08:08 PM
06/05/19 08:08 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Are you trying to bait someone on here? work
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Steel Hemi Block Conversion [Re: camaroduster] #2662825
06/05/19 08:44 PM
06/05/19 08:44 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Technically, the Predator heads use a Hemi block....
Re: Steel Hemi Block Conversion [Re: Dragula] #2662863
06/05/19 10:14 PM
06/05/19 10:14 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
shocked
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Steel Hemi Block Conversion [Re: hemi-itis] #2662878
06/05/19 11:08 PM
06/05/19 11:08 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't know anything about a wedge but the 572-13 heads also use a hemi block. And I figured the best B-1's would too, but I don't know anything about such things. I assume a max performance wedge head should use a hemi block. It lets you put the ports where you want them.
2011 Drag Pak Challenger
Re: Steel Hemi Block Conversion [Re: camaroduster] #2662879
06/05/19 11:10 PM
06/05/19 11:10 PM
Probably not unless the spend a ton of money and effort on that deal scope twocents
Re: Steel Hemi Block Conversion [Re: camaroduster] #2667217
06/18/19 02:16 PM
06/18/19 02:16 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Yes, you need to tap the top row of head stud bosses, probably a 5/8x18 plug, and then redrill and tap the top row for the wedge pattern. They will overlap slightly at the top but will drill into virgin block material within 1/2" because of the taper on the hemi stud boss. There will be some mis-match on water passages if using stock 440 heads, which can be brazed up. Oil drainback on the hemi block will also need to be blocked.. Most aftermarket heads are profiled the same as hemi block and should cover the oil drainback. I think you would need an external drain line from head to block on a B-1 head but not positive. Can't think of any other issues, but definitely can be done with a good machinest.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Steel Hemi Block Conversion [Re: 23T Hemmee] #2667245
06/18/19 03:09 PM
06/18/19 03:09 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Yes it can be done. There's an old thread on here somewhere on how to do it. I think Petty did it back in the day too. Last fall when Jegs had hemi blocks listed I ordered one to do this exact thing. The Jegs block never came through so........
edit found it,
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1578095/wedge-head-on-hemi-block.html
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Steel Hemi Block Conversion [Re: 23T Hemmee] #2667295
06/18/19 05:23 PM
06/18/19 05:23 PM
Texas
Chief Offline
Chief  Offline
Texas
This is what I was told by Koffels.. I have a KB block that I plan to convert to wedge heads so I called them..
Dave Covey
