Re: EFI fuel line ??
[Re: Sniper]
#2662435
06/04/19 11:17 PM
06/04/19 11:17 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Pretty sure Fine Lines or whomever will roll you a set of bigger fuel hard lines There is nothing on Fine Lines web site which indicates they make any lines other that the shorties from the master cylinder. I'll keep searching for another manufacturer.
[Re: GoodysGotaCuda]
#2662511
06/05/19 08:34 AM
06/05/19 08:34 AM
Posts: 6,245 nowhere
Sniper
nowhere
Every remotely modern semi truck headed down the road has nylon braided fuel and oil lines on it that live with absolutely no problems over hundreds of thousands of miles. Yes, diesel is different than gasoline, but today's rubber lines are all ethanol-rated.
Hardlines are fine if that is what you want to run, but they are by far not a requirement for a successful, long-lasting system. Assuming you know how to properly install plastic/nylon lines and have the appropriate tools.
[Re: poorboy]
#2662797
06/05/19 07:54 PM
06/05/19 07:54 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Can I guess too? I think the problem is where the hard line connects to something else. With the pressures many of the efi fuel pumps are putting out, the old rubber hose with a hose clamp can't stand the pressure very long.
I'm running a 97 Dodge efi system on my 39 Dodge truck. Originally I ran a steel line, with slightly flared ends with high pressure efi rubber hose. I clamped the hose to the line with the end of the hose past the flared part of the steel line with a pair of the efi style hose clamps. On 3 different occasions (within a month) The pump blew the hose off the steel lines. Those pumps can pump a lot of gas in a hurry. The only fix that has lasted was when I stepped up to the hard plastic lines with the special ends those plastic line require. Its been well over 6 months and the plastic line are doing well. Haven't had a fuel leak since they were installed.
My guess? The steel lines and short hoses fail too often under the high pressure the efi pumps put out. The flexible plastic lines and their connections do not fail. I would NOT recommend using steel-nickle-copper, or any other hard line with a high pressure hose and high pressure hose clamps. Use the efi designed plastic line with the correct fittings for the plastic lines. Gene That is why you flare the steel line instead of sticking with the bulb/beaded end. 37 degree single flare JIC will work for AN fittings.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2662799
06/05/19 07:56 PM
06/05/19 07:56 PM
astjp2
Utah and Alaska
my guesses: 1. people are lazy, its easy to run a hose and install a few clamps 2. people dont have the skills to work with hard line 3. I will fall back to number 1 which eliminates number 2
[Re: Stanton]
#2663666
06/08/19 12:02 AM
06/08/19 12:02 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I think it is mostly that the flexible lines are easier and cheaper. With the hard lines, you still need flexible hose at each end which is two more hose fittings per flexible line and two more hard line fittings per line, so with a return type system, and extra 4 hose fittings, and 4-hardline fittings. In addition to that, it would be even more expensive for them to supply new hard lines for all the different vehicles. Most cars these aftermarket EFI systems are going on only have 5/16" hard line, and no return line, and on our old cars the old steel lines are likely full of rust and other trash that will get into the injectors. I like new stainless 3/8" hard lines, but it adds several hundred dollars more to go that route.
[Re: moparx]
#2663768
06/08/19 12:08 PM
06/08/19 12:08 PM
Posts: 4,727 Florida
BDW
Wrong post
