Re: How much do you look at your tach when racing? [Re: 383man] #2661841
06/03/19 12:35 PM
06/03/19 12:35 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I only look at the go-pro and yep, I hit the shifts EXACTLY where the light comes on, Always trust my gut and seat of the pants.
The only time I will look at the tach is if I want more RPM for the 2 step on the launch and also what I'm pulling as I cross the stripe.
WIZE
In Car:
Re: How much do you look at your tach when racing? [Re: Streetwize] #2661842
06/03/19 12:41 PM
06/03/19 12:41 PM
an8sec70cuda Offline
I'm about to put a playback tach in my car b/c I can't watch it going down the track.
I watch it in the burnout box, but that's about it. I shift when the shiftlight comes on, or grab 2nd early to come down from a wheelie.
I will glance at it across the stripe.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How much do you look at your tach when racing? [Re: GY3] #2661843
06/03/19 12:43 PM
06/03/19 12:43 PM
A SS or modified4 speed drag race car is a little bit more of a challenge to look at the tach when shifting it, especially whne they have 5.57 rear gears and 2.98 first gear ratio in them work
I've driven and raced 4 speed cars with a 3.09 1st gear with 5.57 rear gears with a 30 inch tall rear tire, I was real busy the first three hundred feet grin
I use to use a tach in the first 4 speed hemi car I raced, I was a lot younger then also, it seemed like it took forever to make one run, now it seems like they don't last as long now even with a new car that is a lot faster confused I guess what I'm trying to say is the more I drive race cars the easier and quicker it seems to go, and I can't focus as well as I use to whiney shruggy
Re: How much do you look at your tach when racing? [Re: Cab_Burge] #2661856
06/03/19 01:09 PM
06/03/19 01:09 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I look at it until I'm in 3rd gear, then I stare at the other car and the stripe.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: How much do you look at your tach when racing? [Re: FlyFish] #2661858
06/03/19 01:24 PM
06/03/19 01:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I really like the shift light better for shifting. I really only look at the tach for staging.
Rich H.
Esse Quam Videri
Re: How much do you look at your tach when racing? [Re: ZIPPY] #2661874
06/03/19 01:51 PM
06/03/19 01:51 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My tach has a shift light option and I was constantly shifting late when I tried to use it. Maybe I'd have to set it up to flash some # of RPM before I want to shift, but then I'm already used to glancing down at the tach when I know the next shift point is coming anyway. I turned off that feature after finding no benefit for me.
Re: How much do you look at your tach when racing? [Re: BradH] #2661876
06/03/19 01:55 PM
06/03/19 01:55 PM
I've told many drag racers who ask what RPM to shift at to shift the tranny when the motor quits pulling hard in each gear work up
I have over revved more than one motor trying to use a tack that was not reading the RPM dead on shock rant
If it doesn't seem right, it probably ain't work grin
Re: How much do you look at your tach when racing? [Re: GY3] #2661925
06/03/19 05:31 PM
06/03/19 05:31 PM
Sterling Heights, MI
John_T_Brown Offline
Haven't used one in years after I installed an air shifter and controlled it with the msd grid. The shift light tells me when the band or clutches are wearing or need adjustment.
If it ain't broke fix it anyway!
