Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: JohnRR] #266117
03/26/09 07:51 PM
03/26/09 07:51 PM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
The bulletin reads in part:
"A new piston will be incorporated into production on the 440 C.I.D. standard engine late in 1971 production.This piston is lighter than the early piston so requires a new crankshaft.
Severe engine vibration will result if the early crankshaft or piston is used in these engines. The engines will be identified with the letter "C" on the identification pad on the top, adjacent to the left block and tappet rail as follows:"
....shows engine serial pad with stampings and goes on to list pn's for pistons and crank.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK #266118
03/26/09 08:01 PM
03/26/09 08:01 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
My buddy is doing a semi restoration on a '70 Charger R/T SE. The motor was a warranty piece that's never been out of the car, obvious by the fact the block is bare metal whereas the heads, intake, oilpan, bellhousing are orange.
Strangest thing is there were 7 six pack rods and one standard.
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: JohnRR] #266119
03/26/09 09:12 PM
03/26/09 09:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Can you post that so it can be READ ???
Go here & click on the scanned image to make it bigger;
http://www.hamtramck-historical.com/images/TSBs/1971/D71-9-8.jpg
It says Std. 440, so it is about the non-HP versions.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: Alaskan_TA] #266120
03/26/09 09:16 PM
03/26/09 09:16 PM
Buffalo, NY U.S.A.
MrNormsTA Offline
MrNormsTA  Offline
Buffalo, NY U.S.A.
Best way is to look at vin tag on dash, crawl under car with a good flashfight, might need a rag with laquer thinner. If stamping on motor looks good and matches last part of vin, crawl out from under car and yell out "yippee I just found a 440 6 pack block".
Rick.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: DPelletier] #266121
03/26/09 11:13 PM
03/26/09 11:13 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
which is why the term "six pack rods" is the biggest misnomer in Mopar history.
The best statment i`ve read in months
And the ONLY good use for those 36+ year old stupid heavy "big" rods
Rick
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: Blown71X] #266122
03/26/09 11:31 PM
03/26/09 11:31 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: MowP4rsn] #266123
03/27/09 02:58 AM
03/27/09 02:58 AM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
440 HD('six pack')connecting rods- an answer to a question that was never asked......
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: mccannix] #266124
03/27/09 08:56 AM
03/27/09 08:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
very INTERESTING , for years the mASSES have been drinking Galen's koolaide and saying that the C denoted special crankshaft for 440-6 engines ... NOT
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: Blown71X] #266125
03/27/09 08:58 AM
03/27/09 08:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Rick
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: JohnRR] #266126
03/27/09 09:39 AM
03/27/09 09:39 AM
NJ
moparply Offline
moparply  Offline
NJ
Does the stamped date on the engine ID pad by the distributor on a 440 refer to the build of the short block or the long block? At what point did Chrysler stamp the spec. info on that pad?
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: moparply] #266127
03/27/09 10:23 AM
03/27/09 10:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I guess it depends on the particular build , if it was a complete engine then it would be of the long block , if it was a partial enngine then it was of the short block ...
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: JohnRR] #266128
03/27/09 10:36 AM
03/27/09 10:36 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
easy it will have one of these on top of it.
Coming soon!!!!
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: Mr.Yuck] #266129
03/27/09 11:07 AM
03/27/09 11:07 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: JohnRR] #266130
03/27/09 12:24 PM
03/27/09 12:24 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And these under that!
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: 62maxwgn] #266131
03/27/09 12:34 PM
03/27/09 12:34 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Courtesy of Barry at www.hamtramck-historical.com
3
Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK [Re: 62maxwgn] #266132
03/27/09 12:46 PM
03/27/09 12:46 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes how could I forget those???
Coming soon!!!!
