Looking for information on a set of W2 heads #2660477
05/29/19 09:33 PM
05/29/19 09:33 PM
tennessee,usa
mattsmopars Offline OP
tennessee,usa
I have a set of W2 heads that I’d like information on if possible. The heads are early and cast 10-1-76 and 8-24-76, and part number 3870810. The have DRE 77823 stamped into both of the heads. I am thinking Diamond Racing Engines, would also guess the same as Diamond/Elkins fame. They have had a pretty heavy port work done, more so to the intake side as those have been made into rectangle ports. Just looking for some information on maybe the original application, as I would think it would take a pretty stout engine to benefit with these heads. Thanks Matt
38042502-3084-4966-83A6-682800D63C4E.jpeg6509AF2F-C50F-4F19-80CB-E26B09922D87.jpegC6AE5A05-63B7-41EF-A961-38B06F10F50A.jpeg7AE23372-826B-40BA-8D29-059FAE4C9FA9.jpeg
Re: Looking for information on a set of W2 heads [Re: mattsmopars] #2660908
05/31/19 11:45 AM
05/31/19 11:45 AM
moparx Offline
moparx  Offline
is that porosity in the bottom pic ?
beer
Re: Looking for information on a set of W2 heads [Re: moparx] #2660923
05/31/19 12:25 PM
05/31/19 12:25 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
In the bottom pic it looks like the threads for the valve cover bolt. I dont know anything about that set. Would definatly have them preasure.tested before would do anything else to them.
Re: Looking for information on a set of W2 heads [Re: NoFrills] #2660927
05/31/19 12:28 PM
05/31/19 12:28 PM
Washington
madscientist Offline
Washington
You can tell that was done along time ago. I never remove all the materiel from the guide boss. And the exhaust port is way too big, but that's how it was done early on.
If they pressure test, there is nothing wrong with them. I doubt you will find an intake manifold that will go that big without a bunch of welding. Even the Pro Dominator won't go that big without welding.
Re: Looking for information on a set of W2 heads [Re: NoFrills] #2660939
05/31/19 01:02 PM
05/31/19 01:02 PM
moparx Offline
moparx  Offline
never gave that a thought. thanks for pointing that out. up
beer
Re: Looking for information on a set of W2 heads [Re: NoFrills] #2660949
05/31/19 01:29 PM
05/31/19 01:29 PM
I've seen that a lot on Mopar SB heads that where heavily ported, use good a thread sealer on the stud or bolts to keep it rom leaking vacuum and sucking in oil from the headsscope up
Re: Looking for information on a set of W2 heads [Re: Cab_Burge] #2660982
05/31/19 03:33 PM
05/31/19 03:33 PM
A727Tflite Offline
A727Tflite  Offline
Oval port was focused at road race, oval track and early drag race.
The square ports were maximum effort drag race heads.
Re: Looking for information on a set of W2 heads [Re: madscientist] #2661070
05/31/19 09:55 PM
05/31/19 09:55 PM
tennessee,usa
tennessee,usa
Yes your correct that is the valve cover bolt threads that you can see. I did have them pressure checked and magna fluxed and they passed both. Also had them cleaned up a little. Could install studs in the VC holes and epoxy around that if need be. He said that and a couple places around the added head bolt reinforcement. The machine shop said no type of issue into any coolant area.
Matt
Re: Looking for information on a set of W2 heads [Re: mattsmopars] #2661073
05/31/19 10:27 PM
05/31/19 10:27 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
My son has a similar set on a 360 he is putting together right now. I am expecting it to kick lots of GM butt. I think they are marked the same.
Sheldon
Re: Looking for information on a set of W2 heads [Re: RUNCHARGER] #2661078
05/31/19 10:45 PM
05/31/19 10:45 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Are these cast iron or aluminium ? Yes I agree they're diamond or diamond-elkins. They look very similar to the heads Glidden ran in about 1980. The valve cover bolt hole is no problem w/ stud & loctite or epoxy. Unless they have cracks they're great w-2s. A flow bench test would be interesting. They're the early style of casting. An indy intake can easly be modified to bolt up if you are happy with a single carb. They could have an intresting history. Make'em work and haul ass !
Re: Looking for information on a set of W2 heads [Re: DavidDean] #2661083
05/31/19 11:12 PM
05/31/19 11:12 PM
tennessee,usa
tennessee,usa
They are cast iron, but very interesting as they are very light color wise compared to the later W-2 castings that I also have. If you look at the other thread in the WIW section you can see the difference between the color of the raw cast iron.
Matt
