Re: SB hyd roller lifters no oil pressure
[Re: AndyF]
#2660616
05/30/19 01:01 PM
05/30/19 01:01 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Not uncommon at all on 340 blocks. Apparently the depth of chamfer on the top can vary quite a bit. Must be it can be an issue on a 360 block as well.
Imo, fundamentally the oil band on the lifters are positioned/sized incorrectly for the application...... since I’ve never heard of this being a problem with a hyd flat tappet lifter. If the lifters have the oil band set up to work in a magnum block, I can see where this could be an issue in a LA block.
Usually bronze lifter bore bushings are the solution.
[Re: AndyF]
#2660709
05/30/19 06:46 PM
05/30/19 06:46 PM
fast68plymouth
So. Burlington, Vt.
The lifters that expose the oil band at high lift are probably designed around the magnum blocks, which have taller lifter bosses.
[Re: AndyF]
#2660710
05/30/19 06:49 PM
05/30/19 06:49 PM
Posts: 4,219 New York
polyspheric
New York
This is caused by the desire to use almost the same product in as many engines as possible. You know, like a Ford Windsor rocker arm in an Oldsmobile?
Boffin Emeritus
[Re: AndyF]
#2663536
06/07/19 03:23 PM
06/07/19 03:23 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Glad to read this. Converting a customers 408 LA to a roller cam setup, so I will go with the Hughes Lifters. I just installed a set of Hylift Johnsons in my 408 Magnum that I got from Brian at IMM, and I still had to remove the Edelbrock heads to replace. Haven't had it at the track yet, however Brian said the Johnson Hylifts would pick up a few RPM's compared to the stock Hydraulic rollers I had.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: ChrgrCuda]
#2663748
06/08/19 09:54 AM
06/08/19 09:54 AM
Posts: 381 Denver CO
bennydodge
Denver CO
I had that problem with a set of Crane hyd. roller lifters years ago when I did my 340 stroker. Problem was solved by using the Doug Herbert solid roller lifters. I believe these are also sold by Howard's as well(exact same part). I've had these in for around 11 years now and 8,000 miles street/strip with no trouble yet-knock on wood lol. Probably other ways to solve this issue now. FYI-these lifters can be removed with aluminum heads still bolted to the engine..
73 Challenger 340(416),E-heads, 727, 3.23 SG 2015 Challenger R/T classic B5, wife's car 2010 Ram 3500 Crew Cab SLT dually 4X4 2016 Challenger Hellcat Redline Red A8
