Top Fuel Transition from 1st to 2nd Gen Hemi #2660302
05/29/19 12:09 PM
05/29/19 12:09 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
I was watching a 1979 movie showing footage of Top Fuel racing in the late '70s and noticed that all of the rear-engine dragsters in the movie were still using 1st generation Hemis (Donovans I assume). So it got me wondering about the transition from 1st to 2nd generation Hemis in Top Fuel and what the timeline was. Also, did anyone ever use a 2nd generation Hemi in a front engine dragster? I also read somewhere that Donovan got Garlits to switch from a 2nd gen to his 1st gen-based Donovan block at one point.
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: 67Satty] #2660320
05/29/19 12:44 PM
05/29/19 12:44 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
I ran a second gen HEMI in my front engine dragster. It was injected on gas though. Was built and run as a JR. fuel when it was built by previous owner
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: mopacltd] #2660321
05/29/19 12:45 PM
05/29/19 12:45 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
Can someone rotate this picture, Please.
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: mopacltd] #2660335
05/29/19 01:03 PM
05/29/19 01:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Hopefully this will work.
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: 67Satty] #2660336
05/29/19 01:04 PM
05/29/19 01:04 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The challenges:
1. the G-1 is too small (4.000" X 3.906") until the stroke is too long
2. the G-2 oil system needs revision, as Garlits said when asked what he did to the passages to make the motor survive "bored some out, stopped some up"
Boffin Emeritus
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: polyspheric] #2660348
05/29/19 01:45 PM
05/29/19 01:45 PM
Originally Posted by polyspheric
The challenges:
Me thinks the conversation with Don Garlits on modifying oil systems was when he fix the crankshaft rod oiling passage direction on the Donovan motors work scope
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: 67Satty] #2660350
05/29/19 01:49 PM
05/29/19 01:49 PM
Don Garlits did help Donovan fix a oiling problem on the crank shaft rod journal oil passage direction early on, maybe 1973/74 confused
I was lucky enough to have several different conversation with him at the races and off track.
He is one of the best drag racers and people here on Earth bow twocents
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: Cab_Burge] #2660356
05/29/19 02:21 PM
05/29/19 02:21 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
The Ramchargers ran a gen II in a FED starting in about 65, more times than not ran fastest time and or low et of the meet. They were "on" to the advance issue with the 426 style before anyone else. Brilliant unequaled team.
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: 67Satty] #2660357
05/29/19 02:22 PM
05/29/19 02:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The switch started shortly after the Gen II came out. (You will see more videos explaining this.) So, yes, front motor dragsters had 426's. (The footage you saw just happened to have a lot of Donovans in it.) Most everybody was running the KB in the late 70's. And yes, Bigs ran the Donovan for a year in the late 70's. Trying to make it work. But he couldn't get it to run as good as his KB.
2011 Drag Pak Challenger
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: Cab_Burge] #2660364
05/29/19 02:38 PM
05/29/19 02:38 PM
New York
polyspheric Offline
polyspheric  Offline
New York
He was referring specifically to the 426 engine. Donovan = 392 G-1 @ 4.125" bore.
Boffin Emeritus
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: polyspheric] #2660367
05/29/19 02:52 PM
05/29/19 02:52 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
This is Big Daddy's first Gen II Hemi from the fall of 64.
https://garlits.com/portfolio-items/swamp-rat-8/?portfolioCats=28
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: rickseeman] #2660396
05/29/19 05:10 PM
05/29/19 05:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
In the '70's even the low budget TF guys had switched to gen II hemi's - mostly iron blocks from Chrysler or wreckers. Big budget "pro's" had aftermarket aluminum blocks.
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: Stanton] #2660445
05/29/19 07:43 PM
05/29/19 07:43 PM
If my memory is correct I think Donovan came out with their 417 C.I. aluminum 392 style hemi block in 1971 or so and Milidon soon followed in 1972 with their Gen 2 426 aluminum blocks shruggy
I'm not sure when KB got into the aluminum block business confused
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: Cab_Burge] #2660471
05/29/19 09:07 PM
05/29/19 09:07 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would say the first Keith Black 426 Hemi aluminum block was 1974.
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: rickseeman] #2660593
05/30/19 11:59 AM
05/30/19 11:59 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I recall watching a recorded conversation with Garlits (YouTube?) where he was discussing going through the conversion to the 426 seems he couldn’t get it to run and it kept hurting itself. After trying different things he decided to go against current knowledge and throw a bunch of timing at it. The thing came alive and stopped hurting parts.
Re: Top Fuel Transition from 1st to 2nd Gen Hemi [Re: CMcAllister] #2660664
05/30/19 04:34 PM
05/30/19 04:34 PM
IL
Dart451 Offline
Dart451  Offline
IL
If I remember the urban myth correctly he advanced the timing to blow up gen 2 so he could run the backup gen 1 engine
Car come alive and the rest is history
