soft plug behind camshaft on 340 #266033
03/25/09 12:17 PM
03/25/09 12:17 PM
central new york
pettyblue440 Offline OP
central new york
where is the best place to find one of these. The one I have is close but is not tight in the hole. Thanks, jon
Re: soft plug behind camshaft on 340 [Re: pettyblue440] #266034
03/25/09 12:37 PM
03/25/09 12:37 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Mopar sells a block hardware kit that has the correct plug in it:
http://store.summitracing.com/partdetail.asp?part=DCC%2D5249261AB&autoview=sku
Re: soft plug behind camshaft on 340 [Re: 69Cuda340S] #266035
03/25/09 01:04 PM
03/25/09 01:04 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Any parts store that has core plugs should have it.
Re: soft plug behind camshaft on 340 [Re: pettyblue440] #266036
03/25/09 01:10 PM
03/25/09 01:10 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
you mean the one behing the block by the distributor gear? kinda shallow and concave? mine were always loose too. i just hammered them in and the flatten and expand.
or do you mean the small ones behind the thrust plate at the front of the block
Re: soft plug behind camshaft on 340 [Re: aarcuda] #266037
03/25/09 01:29 PM
03/25/09 01:29 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Re: soft plug behind camshaft on 340 [Re: aarcuda] #266038
03/25/09 02:01 PM
03/25/09 02:01 PM
Upper Midwest
Upper Midwest
That is one reason they are called expansion plugs. This is the way that that type of plug is installed. Dimple the center to expand the peremeter.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: soft plug behind camshaft on 340 [Re: MoparforLife] #266039
03/25/09 02:29 PM
03/25/09 02:29 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: soft plug behind camshaft on 340 [Re: rockerbob] #266040
03/25/09 02:51 PM
03/25/09 02:51 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I take the used one and nest it in something soft like a folded towel, a shot bag would be perfect. Then I tap it back to shape and reinstall it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: soft plug behind camshaft on 340 [Re: CJK440] #266041
03/25/09 04:00 PM
03/25/09 04:00 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Dodge dealer 1821722 superseded by 2863071 $2.90 I wouldn`t chance reusing it as it would be a pain to fix if it leaked. Put the new one in with a little sealer on the edge and dimple as mentioned.
Re: soft plug behind camshaft on 340 [Re: CJK440] #266042
03/25/09 04:04 PM
03/25/09 04:04 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
man, youse so cheap, youse woulda takin a used expansion plug, redimpled it and a reused it.
