Best rattle can black recommends for k member/trans mount #2660279
05/29/19 11:28 AM
05/29/19 11:28 AM
Alberta
4mulaS Offline OP
4mulaS  Offline OP
Alberta
Looking for recommends on brand(s) for satin finish rattle can black paint. Would like something durable that sticks. All parts are freshly media blasted so no primer versions would be a plus too.
66Scar
Re: Best rattle can black recommends for k member/trans mount [Re: 4mulaS] #2660281
05/29/19 11:37 AM
05/29/19 11:37 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Rustoleum
Re: Best rattle can black recommends for k member/trans mount [Re: CSK] #2660313
05/29/19 12:29 PM
05/29/19 12:29 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Eastwood Extreme Chassis black.
Re: Best rattle can black recommends for k member/trans mount [Re: burdar] #2660317
05/29/19 12:40 PM
05/29/19 12:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I think I've used that in the past, but also VHT's epoxy chassis paint. That stuff turned out really nice on my rollbar... but watch out for the fumes! If I ever come down with "black lung", that's going to be the reason. puke
Re: Best rattle can black recommends for k member/trans mount [Re: BradH] #2660351
05/29/19 01:53 PM
05/29/19 01:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Re: Best rattle can black recommends for k member/trans mount [Re: 4mulaS] #2660383
05/29/19 04:07 PM
05/29/19 04:07 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
for spray can paint VHT is some good stuff ! probably the only reason my car has not rusted away to nothing
Re: Best rattle can black recommends for k member/trans mount [Re: 4mulaS] #2660460
05/29/19 08:35 PM
05/29/19 08:35 PM
Alberta
4mulaS Offline OP
4mulaS  Offline OP
Alberta
Well, at the end of the day I just finished spraying 18 backing plates, 4 upper control arms, a big block kmember, 4 speed trani mount all in Eastwood chassis black. I had a pint of it lying around but was feeling lazy and initially didn’t want to clean the gun afterwards. Glad I did it though, the have turned out great after a couple coats, will take them off the line tomorrow after they are cured enough to handle.
Thanks for all the replies
66Scar
Re: Best rattle can black recommends for k member/trans mount [Re: 4mulaS] #2660526
05/30/19 06:30 AM
05/30/19 06:30 AM
fullmetaljacket Offline
VHT Chassis satin black all the way. Trust me on this spray paint stuff.
