Help needed / wanted. Hardware Platting #2659715
05/27/19 06:52 PM
05/27/19 06:52 PM
Mid-West
P
ply478 Offline OP
ply478  Offline OP
P
Mid-West
Zinc or other bright platting:
Looking to see if someone does or knows of a company that will do a small batch of bolts and hardware for a small project I have.
Not car related. (Motorcycle)
If you do this please contact me. Willing to pay for a good job. I can prep the bolts and hardware to your specs.
If you know of any company that does this. Let me know the name and location.
Help a brother out for a kewl project!
PLY 478
I am also a Vintage Motorcycle guy. Mainly Spanish built "Bultaco's" If you have one or parts PM me.+
Re: Help needed / wanted. Hardware Platting [Re: ply478] #2659724
05/27/19 07:26 PM
05/27/19 07:26 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I used this local plater for parts on my Duster restoration. They did a great job at a great price. Ubfortunately, There are a few miles between you and them.
https://www.klplating.com/
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Help needed / wanted. Hardware Platting [Re: FJR doc] #2659767
05/27/19 09:34 PM
05/27/19 09:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Member 3404 (if I remember correctly) has done some small 1-car batches for me, great results, inexpensive, timely turnaround.
Not sure if he's still here or doing that, but I used him 3 times, last time was a few years back.
His name is Eric and I think he's in Ohio.
Re: Help needed / wanted. Hardware Platting [Re: topside] #2659847
05/28/19 07:28 AM
05/28/19 07:28 AM
Mid-West
P
ply478 Offline OP
ply478  Offline OP
P
Mid-West
Thank you. I sent 3404 a message.
PLY478
Re: Help needed / wanted. Hardware Platting [Re: ply478] #2659944
05/28/19 11:40 AM
05/28/19 11:40 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Key City Plating in Dubuque, IA
Re: Help needed / wanted. Hardware Platting [Re: burdar] #2660052
05/28/19 03:24 PM
05/28/19 03:24 PM
Mid-West
P
ply478 Offline OP
ply478  Offline OP
P
Mid-West
Do you know that they do small batch work?
Do you have a contact name there?
PLY478
Re: Help needed / wanted. Hardware Platting [Re: ply478] #2660088
05/28/19 05:00 PM
05/28/19 05:00 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
They used to do small batches. They've done three batches for me. The last batch I had them do was was probably 4 years ago. You'll just have to call and ask. No special contact, I just called and talked to whoever answered the phone. They did all the fasteners for my Challenger and Dart. I also had them do my kickdown linkages, coil bracket exc.(same price as their standard barrel plating charge)
They were extremely reasonable on price. I stripped all my fasteners myself. I gave Key City perfectly clean parts to start with.
I initially had my Dart fasteners done at a place local to me.(Cedar Rapids) They were more expensive AND the silver zinc parts came out with a yellow tint. They said that their solution was different and that it would withstand a longer salt spray.(that's why the color was off) I didn't like the color so I had Key City run them through a second time.
Re: Help needed / wanted. Hardware Platting [Re: burdar] #2660099
05/28/19 05:58 PM
05/28/19 05:58 PM
Nanuet, NY
johntpr Offline
johntpr  Offline
Nanuet, NY
69 Daytona 4 speed
Re: Help needed / wanted. Hardware Platting [Re: johntpr] #2660249
05/29/19 09:50 AM
05/29/19 09:50 AM
moparx Offline
moparx  Offline
this is a dumb question, but how does a guy keep the plating on fasteners looking good during normal use without the plating changing color, or coming off ?
is there a coating that can be applied, [using RPM as an example] ?
beer
Re: Help needed / wanted. Hardware Platting [Re: moparx] #2660342
05/29/19 01:17 PM
05/29/19 01:17 PM
Miami, FL
W
wylde8 Offline
wylde8  Offline
W
Miami, FL
I went through this same dilemma about two years ago. Eventually I found a place here in St. Louis that does it. I've had them do two small batches for me and it all came out nice.
https://microfinishco.com/
1971 Dodge Charger
At Moparts, the concensus is there is no consensus.
Re: Help needed / wanted. Hardware Platting [Re: wylde8] #2694295
09/04/19 11:30 AM
09/04/19 11:30 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Anyone had any luck reaching Eric (3404)?
Re: Help needed / wanted. Hardware Platting [Re: ply478] #2695314
09/07/19 09:34 PM
09/07/19 09:34 PM
N. of New Orleans
493 70 Runner Offline
N. of New Orleans
Dynamic Renovation
Dynamic Renovation
Re: Help needed / wanted. Hardware Platting [Re: 493 70 Runner] #2695389
09/08/19 09:59 AM
09/08/19 09:59 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Call a couple local plating companies. One by me says they'll just throw a small batch in (no charge) to help a car guy.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Help needed / wanted. Hardware Platting [Re: 71TA] #2695574
09/08/19 09:06 PM
09/08/19 09:06 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I always encourage folks to get started with doing their own plating, once set up it’s really not that difficult. I decided to give it a try several years ago and have no regrets. We’ve all been ready to put an assembly together only to discover you are either missing a fastener or have forgotten to have it plated. It also gives the flexibility to change fasteners at will when you find out you have a finish incorrect
Re: Help needed / wanted. Hardware Platting [Re: AAR#2] #2695781
09/09/19 12:48 PM
09/09/19 12:48 PM
British Columbia
chrisf Online content
chrisf  Online Content
British Columbia
I bought a large plating system a few years ago and just recently got it up and running. doing zinc base coat with chromium top coats (yellow black and blue/clear) i am lucky as i have all the tools in the toy box to clean and prep but its still a ton of work and very time consuming. I thought about it to add to my business but its just too much work for the return. talking to a bike guy locally he just paid $8 per bolt that he had refinished so i think the resto world vs the industrial world has very different pricing (and quality?) i am still learning so wont give up on it yet.
Re: Help needed / wanted. Hardware Platting [Re: chrisf] #2695893
09/09/19 06:12 PM
09/09/19 06:12 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Nice results, particularly when considering you’ve just started. Not trying to highjack the thread so I’ll send a pm with more info.
Re: Help needed / wanted. Hardware Platting [Re: chrisf] #2696079
09/10/19 10:44 AM
09/10/19 10:44 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Eric Manual (3404) is a very good friend of mine, he is local and has done all my plating for years. He is a huge MOPAR guy, he hand does all my fasteners, latches and anything else I have him do. He was one of the original platter's for the MOPAR hobby for years, now he's all grow up and runs the plating company he's been at for years. He does all the side jobs after hours on his own time. Here is the company he runs www.elyriaplating.com, ask for Eric (Da man).
Re: Help needed / wanted. Hardware Platting [Re: HEMICUDA] #2696098
09/10/19 11:23 AM
09/10/19 11:23 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I have used this shop for years. He does excellent work and has never lost a single bolt, nut, or screw. Turn around time is very reasonable too. http://detailplating.com/
