Budget 383 Build #2659344
05/26/19 01:48 PM
05/26/19 01:48 PM
michigan
6pakdakota Offline OP
michigan
I am getting ready to put a 383 together for my 85 D100. The truck will be used as a daily driver during the summer and should weigh about 3900 pounds with driver. I would like the truck to run 12s and use some of the parts I have laying around collecting dust. Here is what I have to work with.
.030 over 383 with flat top pistons .030 in the hole with no valve reliefs. It should be about 8.5:1.
346 heads mildly ported with 2.14/1.81 valves
Factory rockers
Weiand action plus intake
750 Holley
1 3/4 headers
727 trans with shift kit
TCI Breakaway torque converter
8 3/4 rear end with 3.23, 3.91 or 4.10 gears
I still need a new camshaft and would prefer a hydraulic flat tappet. Do you guys have any suggestions for a good shelf cam that will help me reach my goals and work with the pistons I have? Also if you see anything that might not work let me know and thanks in advance.
Here is a picture of the truck it’s going in. It’s the one towing the trailer.
Re: Budget 383 Build [Re: 6pakdakota] #2659351
05/26/19 02:32 PM
05/26/19 02:32 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
If it's going to weight 3900 and run a high 12, buy a nitrous kit for it.
Re: Budget 383 Build [Re: 6pakdakota] #2659365
05/26/19 03:50 PM
05/26/19 03:50 PM
Quote
One of the (2) Summit house brand cams. 3.23 gears.
Re: Budget 383 Build [Re: 6pakdakota] #2659373
05/26/19 04:20 PM
05/26/19 04:20 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I think going high 12s with the parts you have will be tough to do. I could be wrong, but I bet the TCI breakaway is similar to the factory hi stall. 383s need some converter. This would be much easier with a 440 but I realize you already have the parts. Big stall ,big gear and big cam in the engine you have might reach your goal but will take away some of the streetability. Depends on what you can live with. As Moparpollack suggested, you could put a kit on it.
Re: Budget 383 Build [Re: forphorty] #2659386
05/26/19 04:45 PM
05/26/19 04:45 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
4.10's, better juice it.
Sheldon
Re: Budget 383 Build [Re: RapidRobert] #2659395
05/26/19 05:07 PM
05/26/19 05:07 PM
michigan
michigan
Originally Posted by RapidRobert
Quote
The larger of the two summit cams doesn’t seem too bad. Do you know if these are a quality piece? I wouldn’t mind more lift, but I’m not sure if I would have clearance issues.
Re: Budget 383 Build [Re: moparpollack] #2659396
05/26/19 05:11 PM
05/26/19 05:11 PM
michigan
michigan
It probably will get a small wet kit too. Lol
Re: Budget 383 Build [Re: 6pakdakota] #2659414
05/26/19 06:58 PM
05/26/19 06:58 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
i have used a few with no issues.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Budget 383 Build [Re: 6pakdakota] #2659444
05/26/19 08:22 PM
05/26/19 08:22 PM
Quote
I have one, not yet used. Several people have recommended em with no issues so I pulled the trigger on one for a mild build. Not sure if you have enough P/V clearance or not but .030" IS pretty close to the top.
Re: Budget 383 Build [Re: RapidRobert] #2659490
05/26/19 10:23 PM
05/26/19 10:23 PM
The lobe separation angle and lift and duration at from 30 degrees BTDC to around 15 ATDC on the intake valves makes the valve get close to the piston tops work A cam ground on a 105 LSA with 260 degrees @.050 installed at 105 LSA will have less V to P clearances than the same lobe put on a cam with 110 LSA installed at 110 on the intake lobes in the same motor work shruggy
Re: Budget 383 Build [Re: 6pakdakota] #2659552
05/27/19 09:14 AM
05/27/19 09:14 AM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
It doesn’t look like a 12-sec package to me, but you have the parts and the plan........ and it will run what it runs.
Re: Budget 383 Build [Re: fast68plymouth] #2659556
05/27/19 09:35 AM
05/27/19 09:35 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
I built a 383 almost identical to what you are planning. I used a Crane cam powermax cam with .467/.494 lift with 114* LSA. It was in an 86 short bed truck with 3.23 or 3.55. It ran 15.0.
Re: Budget 383 Build [Re: sportfury70] #2659573
05/27/19 10:19 AM
05/27/19 10:19 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Yes: That is what I would expect. Like I say 4.10's, juice it and get a convertor.
Sheldon
Re: Budget 383 Build [Re: 6pakdakota] #2660103
05/28/19 06:27 PM
05/28/19 06:27 PM
michigan
michigan
It looks like my short block is not as good as I thought. The crank needs to be reground, so I am going to zero deck the block and mill the heads to get the compression up to 9.5:1.
Re: Budget 383 Build [Re: 6pakdakota] #2660117
05/28/19 07:23 PM
05/28/19 07:23 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It'll be hard and likely not possible to get to where you want to go with what you have, and the overall goal/usage for the truck.
You'll have piston to valve to clearance issues with any cam that has 12-second-potential on a zero deck flat top piston in a 383
Re: Budget 383 Build [Re: 6pakdakota] #2660127
05/28/19 07:56 PM
05/28/19 07:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The combination of short stroke and long rods (n = 1.88:1) means the piston is very close to the deck around TDC which limits lift. This narrows your choice of which cam has enough .050" duration (like 240) but low lift or wide LSA.
Your static CR is low for any hot cam.
Your deck clearance is too loose for good quench/turbulence.
Boffin Emeritus
