Nord Lock Washers For Headers #2659653
05/27/19 02:15 PM
05/27/19 02:15 PM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
My TTI headers on aluminum head BB have a tendency to loosen, which requires occasional retightening. Am using studs.
There are a number of locking technologies to help, I did an investigation of several and it appears this is as simple as any, more effective than others, and reasonable in cost. Amazon but not Summit sell.
I did a search on our forum and found no references to their use, which is surprising.
This U Tube video, comparing several options for locking was impressive. There are several such videos.
https://m.youtube.com/watch?v=WPCfd4Zr6rE
Has anyone on the forum used them, and if so,,,opinions?
I am going to order up. Unfortunately sold in packs of 8, headers require 12.
Re: Nord Lock Washers For Headers [Re: Sxrxrnr] #2659694
05/27/19 05:25 PM
05/27/19 05:25 PM
Header gaskests compress under heat, correct? Same thing on bolts or studs when heated they grow in length, correct?
My point is once you retighten them several times they should take a permanent set and stay tight, mine do work
As far as those locking washers on header flanges I would pass down twocents
Re: Nord Lock Washers For Headers [Re: Sxrxrnr] #2659700
05/27/19 05:57 PM
05/27/19 05:57 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Get some remflex gaskets. My bolts never loosened up with them.
Re: Nord Lock Washers For Headers [Re: Sxrxrnr] #2659702
05/27/19 06:17 PM
05/27/19 06:17 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
We used them on critical electrical connections. They are expensive but are a pretty good choice if you are forced to use a fastener that is too short. Do you have room to add a 3/4" long spacer and use a longer stud? The extra stretch length would help.
Re: Nord Lock Washers For Headers [Re: Craig J] #2659741
05/27/19 08:23 PM
05/27/19 08:23 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I use them at work and are a dandy choice for locking things together but like said before that is not the problem gasket crush will require a couple of re-tightenings untill they take a set, once they do then you are as good as gold.
Re: Nord Lock Washers For Headers [Re: Sxrxrnr] #2659830
05/28/19 03:17 AM
05/28/19 03:17 AM
Norway
cudaerik Offline
cudaerik  Offline
Norway
I use the Nordlock 3/8" washers on my engine in combination with remflex gaskets, hooker headers and Eddy heads. No header bolts coming loose and no leaks after five years.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Nord Lock Washers For Headers [Re: cudaerik] #2659839
05/28/19 06:29 AM
05/28/19 06:29 AM
Coastal Maine
Mr onetwo Offline
Mr onetwo  Offline
Coastal Maine
Try Allen's Fasteners for Nordlock washers...good people. https://www.allensfasteners.com/
Re: Nord Lock Washers For Headers [Re: Mr onetwo] #2659969
05/28/19 12:31 PM
05/28/19 12:31 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I've used mrgasket lock washers on mine with the studs and nuts been on there 20+ years.
Re: Nord Lock Washers For Headers [Re: cudaerik] #2659981
05/28/19 12:44 PM
05/28/19 12:44 PM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
Having both remflex gaskets and nord locks(how much thicker are nord locks verses standard lock washer?), were standard length header bolts(or studs) long enough to get a adequate bite into head threads? Having aluminum heads, this could be an issue so as not to strip out threads.
I would guess that upon initial installation a secondary torquing of bolts is still required after a few heating/cooling cycles.
Re: Nord Lock Washers For Headers [Re: rickraw] #2660017
05/28/19 01:47 PM
05/28/19 01:47 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
X2
Using the small head header bolts that came with my super comps.
Re: Nord Lock Washers For Headers [Re: Sxrxrnr] #2660231
05/29/19 08:14 AM
05/29/19 08:14 AM
Norway
cudaerik Offline
cudaerik  Offline
Norway
I'm using 1" ARP bolts with the Nordlock washers and the Remflex gaskets.
Re: Nord Lock Washers For Headers [Re: Mr onetwo] #2660466
05/29/19 08:49 PM
05/29/19 08:49 PM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
Placed them in my contact list. Well sorted website.
