What master cylinder #2658998
05/25/19 09:20 AM
05/25/19 09:20 AM
Hazlet nj
Joemoy29 Offline OP
Joemoy29  Offline OP
Hazlet nj
I have a 72 cuda with front disc and 11” drum in rear. Had manual brakes. I cannot find a master cylinder listed for this application... any help would be great
Re: What master cylinder [Re: Joemoy29] #2659005
05/25/19 09:41 AM
05/25/19 09:41 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
According to the specifications in the 72 Plymouth FSM, which can be freely downloaded here, the master cylinder is the same for power or manual disc brakes.
Rockauto lists several choices.
Re: What master cylinder [Re: Joemoy29] #2659680
05/27/19 04:06 PM
05/27/19 04:06 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
On my 70 Challenger that originally came no power brake, drum brakes. Replaced drums with discs. Horrible brake action that required excessive pedal force to stop car.
Finally installed a very soft pad that helped,,,but ended with filthy wheels after very few miles of driving from brake dust.
After much investigation and complete BS from many “experts”, I learned that smaller MC bore increases braking pressure on discs than does larger bores. Sounds A*** backwards but is true. Found this cylinder, installed it,,,went to very clean ceramic pad, brakes are very good. Original drum brake MC was a larger bore.
Do not know if fits your Cuda,,,but you get the idea,,,,in this case smaller is really better
https://www.amazon.com/gp/product/B001PYO1PU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Re: What master cylinder [Re: Sxrxrnr] #2659998
05/28/19 01:05 PM
05/28/19 01:05 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
On my 1970 Charger I'm using the 7/8 wheel cylinders and 15/16 master cylinder. The pedal feels good.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: What master cylinder [Re: 70sixpkrt] #2681105
07/25/19 07:07 AM
07/25/19 07:07 AM
London, England
Gavin Offline
Gavin  Offline
London, England
This has been addressed a number of times so definitely worth a search on the board, but yes the consensus is to use the 15/16 bore master cylinder, as shown in the link (or if you are not worried about looking stock-ish, an aluminum 15/16 based on the later model if anyone is still offering them). Note the original application for the iron one was mid-70's A-Bodies with POWER brakes, don't be put off by that, this is what you need for your manual discs on your Cuda. The 7/8" rear cylinders also a good idea, though you have 11" rear drums rather than 10", so not sure if this would affect that choice.....
Re: What master cylinder [Re: Gavin] #2681189
07/25/19 10:33 AM
07/25/19 10:33 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
surprisingly the 10 brake has more pad area than the 11 inch brake-----
