TTI 440-200/ Tremec 5sp #2658439
05/23/19 03:23 PM
05/23/19 03:23 PM
TN
68rtcharger Offline OP
TN
Anyone running a Tremec 5sp and TTI headers?
I was told by two people these headers will
#1 guy : No will not work
#2 guy : Yes they’ll work no problem
68 Charger
Any help much appreciated!
Re: TTI 440-200/ Tremec 5sp [Re: 68rtcharger] #2658455
05/23/19 03:59 PM
05/23/19 03:59 PM
AndyF Offline
AndyF  Offline
I don't have any experience with that exact combination of parts but I do have 40 years of experience with aftermarket parts so I'll say that the odds are very low that it will all magically fit together. Aftermarket parts are not designed to work with other aftermarket parts. TTI designed their headers to work with factory transmission so as soon as you put a Tremec 5speed in there you've messed with the system. You might get lucky but be prepared to cut and weld.
Re: TTI 440-200/ Tremec 5sp [Re: 68rtcharger] #2658463
05/23/19 04:24 PM
05/23/19 04:24 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
I ran them w/400 E RPMs and 400 w/Indy SRs with TKO & QuickTime Bellhousing, no problem. I think I doubled or tripled the gaskets with the RPMs. Don't think the transmission is an issue, just the bellhousing if any on your car. But it was a good while ago
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: TTI 440-200/ Tremec 5sp [Re: 68rtcharger] #2658503
05/23/19 06:13 PM
05/23/19 06:13 PM
Norway
General 68 Offline
General 68  Offline
Norway
I run 2" TTI header/3" x-pipe. 68 Charger, 440/TKO 600/Lakewood Scattershield. Bought 2007.
Had to trim the bolt flange on the scattershield slightly at one spot and grind a little off of one flange nut. All else were good.
Re: TTI 440-200/ Tremec 5sp [Re: General 68] #2658551
05/23/19 09:00 PM
05/23/19 09:00 PM
TN
TN
Awesome!!! Thank you
The guy that told me it would fit almost mirrored your reply
Thanks for the replies everyone
Another question
What does Tremec and TTI specify the end of the output shaft has to be in the exact same location as the factory 833??
Re: TTI 440-200/ Tremec 5sp [Re: 68rtcharger] #2658655
05/24/19 04:37 AM
05/24/19 04:37 AM
Norway
General 68 Offline
General 68  Offline
Norway
Not sure if I understand your question, but I guess they do it to keep correct driveline geometry and keep the exhaust tucked correct up under the car. X-pipe also takes up some space around the drive shaft.
