Lowered D150 Bump Stop
#2658114
05/22/19 05:59 PM
05/22/19 05:59 PM
Posts: 134 SE, Idaho
Spider
SE, Idaho
For those that have lowered their 72-93 half-ton trucks, I am looking for pictures and ideas on what to do with the bump stop.
I know that people have cut the bump stop mount completely out, but I hate doing "permanent" mods.
Anyone ever try just removing the rubber bumper?
I am using van lower control arm.
73 Cuda 340 85 D100 2010 Procharged Road Glide
Re: Lowered D150 Bump Stop
[Re: mopeman]
#2658124
05/22/19 06:14 PM
05/22/19 06:14 PM
Spider
SE, Idaho
The mount or just the rubber?
[Re: Spider]
#2658131
05/22/19 06:28 PM
05/22/19 06:28 PM
Posts: 615 Id
mopeman
Id
The rubber bumper, that way I still had some cushion.
Mopar or no car MoPar=Massivly Over Powered And Respected!
'93 W250 Ram '68 Charger '67 Coronet 500 my steet/strip rod-now a 6BBL!
[Re: stumpy]
#2658132
05/22/19 06:28 PM
05/22/19 06:28 PM
Spider
SE, Idaho
When I lowered mine I just cut the rubber down. Cool! That's what I want to do. Does it hit often? Did you cut a couple inches?
[Re: 68dodge]
#2662390
06/04/19 09:23 PM
06/04/19 09:23 PM
Posts: 381 Bay area, CA
Californian
Bay area, CA
I've got my 76 lowered on van lower control arms and there is only 3/4" of space between the arm and the steel mount for the bump stop. I know they are the original springs. How much gap should there be between the mount and the lower control arm?
1976 Dodge Californian
360, Thermoquad, 727 trans, 9.25 rear with 3.21 gears and a sure grip style rear.
