How Much Compression for a Stroker? #265801
03/25/09 02:42 AM
03/25/09 02:42 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Just a question for a stroker, say a 500 or 511, if running a cam with 250ish degrees duration at .050, how much compression do you think would be safe for pump gas? And how much compression do you think it would take to give good results with a cam like that in the 500 cube stroker?
Looking for a cam that will work well with a stockish stall (2500) converter and 3.23 gears.
Re: How Much Compression for a Stroker? [Re: GTX MATT] #265802
03/25/09 02:59 AM
03/25/09 02:59 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Assuming Aluminum heads & effective quench in the 10.5-10.8 range.. You really should look at dynamic C/R & shoot for a cylinder pressure around 155-160 psi...
Re: How Much Compression for a Stroker? [Re: GTX MATT] #265803
03/25/09 06:27 AM
03/25/09 06:27 AM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
im running just about the same thing except for i was useing 915 heads at about 70cc. right around 12.5 to 1 on 93 oct with a mopar .484 cam. and it was the limit i would say switching to eddys this year and hopeing to mill them .070 and run off pump again
Re: How Much Compression for a Stroker? [Re: n_bogie1984] #265804
03/25/09 08:20 AM
03/25/09 08:20 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
11-11.5:1 with tight quench and AL heads, no problem on 93.
2017 Grand Cherokee Overland
Re: How Much Compression for a Stroker? [Re: patrick] #265805
03/25/09 11:52 AM
03/25/09 11:52 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you want to run a mild cam, I would keep comp around 10.5 and for sure under 11.
Re: How Much Compression for a Stroker? [Re: DaytonaTurbo] #265806
03/25/09 11:53 AM
03/25/09 11:53 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
It would be using iron heads for the time being, aluminum when the budget allows.
Re: How Much Compression for a Stroker? [Re: GTX MATT] #265807
03/25/09 12:02 PM
03/25/09 12:02 PM
hemisurfer Offline
hemisurfer  Offline
You can go with more compression with aluminum up to 11.5 max and that is pushing it.
The iron heads much less. I would keep it at 10.5 max with the iron and again that's pushing it.
Keep an eye on your timing if you get any detonation, less is better with todays cruddy gas.
Chris
Re: How Much Compression for a Stroker? [Re: GTX MATT] #265808
03/25/09 12:09 PM
03/25/09 12:09 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
It's difficult for me to comment but I will. If you stay with iron heads, then I'd stick with anything under 11.0 on cr. Probably the most critical issue in your plan is quench. A .040 quench is optimal as it reduces detonation. This does however need flat-top pistons and a closed chamber head to be fully effective. Open chamber heads and dome postons can be made to quench but that normally results in a much higher compresion ratio. A cam that is at 250 @ 050 will work with good quench. If you build good cylinder pressure w/o quench, you may get a significant amount of detonation. Since I am at altitude, building cylinder pressure is much more difficult so my real would result's will not be the same as yours. I'll stop rambling. You really need good cylinder pressure and quench to go to the supposed limit of 11.0 cr on an iron headed motor. I'd welcome any rebuttal to this comment.
Re: How Much Compression for a Stroker? [Re: BELVEDERE67] #265809
03/25/09 12:21 PM
03/25/09 12:21 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Wow, this is at least a full point more than I expected, with 500 cubes I figured 9.5:1 would be pushing it with iron heads and 93. Keep the comments coming, im trying to sqeak by with upper 9s or lower 10s with the irons so that I can be in the mid to upper 10s when I go aluminum.
And for the best quench, I guess the easiest way would be zero deck and .039 inch head gasket?
What if I do not have good quench and am, say, .020 in the hole to make things more realistic.
Re: How Much Compression for a Stroker? [Re: GTX MATT] #265810
03/25/09 01:44 PM
03/25/09 01:44 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Even with a flat-top piston, zero deck, thin gasket and open chamber heads you will not have enough quench which increases the chances of detonation. Use the Keith Black compression calculator to keep compression ratio below 10.5 (I think 10.5 is borderline unless running aluminum heads or closed chamber steel; 67 heads)); we ran 10.0 with 34 degrees, open chamber steel heads and 93 octane with poor quench (too much clearance).
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: How Much Compression for a Stroker? [Re: GTX MATT] #265811
03/25/09 02:20 PM
03/25/09 02:20 PM
And for the best quench, I guess the easiest way would be zero deck and .039 inch head gasket? What if I do not have good quench
(1) that's perfect(w closed chamber heads) but with open ch you would need to mill each recess to equalize the depth and slope AND use quench pad pistons & CAREFYLLY measure & then mill the piston top to achieve the aforementioned distance. A PITA but definitely worth it, the end result being able to run much more CR on the same octane and SQUEEZE is POWER plus the resulting turbulence from the mixture being squished out from the tight space makes for a more homogenized mixture also benefitting power, mileage, emissions in addition to the #1 perk the reduced detonation. (2) Much above ~.045 you lose the quench benefit. If you do not go to the trouble of achieving it you are leaving something on the table no matter what you add for cam/heads/carb ign. The foundation must be right.
Re: How Much Compression for a Stroker? [Re: RapidRobert] #265812
03/25/09 03:20 PM
03/25/09 03:20 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
I did a 470" low deck.4.375 x 3.900, 6.760 rod. Right at 10.2:1. 84cc Eddys and a small dish(mirrors the chamber) w/.039 felpro's at 0 deck.I know I could have went higher,but I am unsure what pump swill will be available in a couple yrs. Has a 242/248@.050 solid roller,runs great on 93 and no ping on 89(that was an oops at the gas station ) This is a street only car.Hope that helps.
Re: How Much Compression for a Stroker? [Re: Dcuda69] #265813
03/25/09 03:38 PM
03/25/09 03:38 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
http://www.projectpontiac.com/ppsite/content/view/16/30/
Try this link, it works well and gives you a look at both CR and DCR. You will need the cam specs. I would say iron heads under 8.5:1 DCR.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: How Much Compression for a Stroker? [Re: GTX MATT] #265814
03/25/09 07:03 PM
03/25/09 07:03 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You know that you'll need to be a little creative to do this and have both good quench and reasonable CR under these two conditions with out changing pistons - right?
I would not go over 10.5 CR with aluminum heads, based on what you describe for your combination.
Re: How Much Compression for a Stroker? [Re: BSB67] #265815
03/25/09 07:48 PM
03/25/09 07:48 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
i still think your all nuts just entered my specs and this is what i got
499.1 ci
8.18 lifter
13.76 to 1 static
10.46 to 1 dyna
off 93 oct, 34 deg timing and 915 heads
Re: How Much Compression for a Stroker? [Re: n_bogie1984] #265816
03/25/09 08:11 PM
03/25/09 08:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Did he say open chamber heads ?? I did not see which heads he said other then iron heads. That said I use 906 open chamber iron heads in the 440 in my 63. And I use the KB quench pad pistons. I had to work the pistons and chambers to get all my chambers in the .040 to .045 quench area and I got it to come out at 10.0 comp. I can run 38 total timing all in by 2000 rpm and I run 92 and 93 pump with no ping. I use the MP .557 cam with 296 advertised duration and it works nice with my combo. Ron
Re: How Much Compression for a Stroker? [Re: 383man] #265817
03/25/09 10:40 PM
03/25/09 10:40 PM
IN
ahy Offline
ahy  Offline
IN
In part it depends on how you'll use it. Pushing compression up on a drag car which has a short run followed by cooldown is different than on a street driven car that will see traffic, high underhood temps and possible sustained hard running.
I guess I'm more conservative than many posters or perhaps its because its how I use my car. Your combo sounds like you plan to drive it based on cam and convertor choice. Also if you start with open chamber iron heads and convert later to aluminum, you won't be able to use quench dome pistons very well so the iron headed engine probably won't be a quench engine.
Assuming you are starting with open chamber iron heads, I'd shoot for mid to high 9's - say 9.7 - with a D dish piston at zero deck. When you put smaller chamber aluminum heads on that would get you in the low to mid 10's. You might be close on detonation with the iron heads but should be bulletproof with the aluminum heads and quench.
Re: How Much Compression for a Stroker? [Re: ahy] #265818
03/26/09 12:25 AM
03/26/09 12:25 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Sorry guys didnt specify, they are 516 closed chambers. I know I know, they wont work well but they have a fresh valve job and I cant see dropping the dough for machine work on a set of 906s and the price of cores for something that will get changed a year later.
Re: How Much Compression for a Stroker? [Re: GTX MATT] #265819
03/26/09 12:38 AM
03/26/09 12:38 AM
Closed chambered 516's now and are you going to closed chambered alum ones when you switch(hope so) & if so are the cc's of the 2 close enough that you can get your CR where you want it now & have it pretty much the same when you switch to alum heads & you'll still have your quench(if you get it now) & if the cc's are radically different & you're switching in a year I'd get the CR where you want it based on the cc's of the upcoming swap
Re: How Much Compression for a Stroker? [Re: RapidRobert] #265820
03/26/09 12:58 AM
03/26/09 12:58 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Yes I think the compression will be pretty close, what does a 516 chamber cc at, 83-85? I know 78 is what its supposed to be, but thats blueprint spec.
Also, the compression ratio options are slightly different if I run a 493 or a 505, what are the disadvantages to the 505? It has smaller Chevy rod mains, is that something to seriously consider? It will be a street driven engine, flooged quite a bit, and will see the strip to see what it runs and tune it to get the best results and have fun.
The difference in stroke is only .1 inch, I couldnt imagine im comprimising much in durability. But at 6000 rpm, is it really going to make a difference or no? Its only 12 cubes, but 12 cubes is 12 cubes.
Should I just pick the one that yeilds me the compression I really want?
