Page 1 of 3 1 2 3
D600 #2656163
05/16/19 11:58 PM
05/16/19 11:58 PM
Id
mopeman Online content OP
mopeman  Online Content OP
Id
Ok, so I might be going on a suicide mission and buying a '75 D600 grain truck with a dump 300 miles north of where I live and driving it home! Does anybody have any part numbers for service parts for the 361-4 like the belts, oil filter, air filter and ignition system items? I have a bunch of pictures of the truck and it looks good and the current owner says it runs good, but we all know what means! I might put out a request for a Moparts member to check it out for me before I attempt this.
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: D600 [Re: mopeman] #2656275
05/17/19 01:48 PM
05/17/19 01:48 PM
ND
dodgedon Offline
dodgedon  Offline
ND
What state is the truck in?
We are still using 2 Dodge trucks on the farm. Basic parts are easy to get.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: D600 [Re: dodgedon] #2656306
05/17/19 03:55 PM
05/17/19 03:55 PM
Id
Id
The truck is in Eastern Washington. I wanted to have the parts to take with me when I pick it up, but all the online parts suppliers don't have the D600 in their option list. I guess I'll have to go to Napa and see what I can find.
Mopar or no car
'93 W250 Ram
'68 Charger
Re: D600 [Re: mopeman] #2656442
05/17/19 11:49 PM
05/17/19 11:49 PM
ND
dodgedon Offline
dodgedon  Offline
ND
These trucks used Chrysler's electronic ignition. So if you have spare parts for other Mopars i would take them with.
300 miles in a truck like this will take you a long time to get home. I would guess 7 hours. Maybe more. Think 50-55 and lots of gas.
67 Charger 383 auto
Re: D600 [Re: dodgedon] #2656448
05/18/19 12:12 AM
05/18/19 12:12 AM
Id
Id
Yes it has electronic ignition, so spare ballast resister and ECU will be in the parts bag. It's about a 6 hour drive in a regular vehicle so if I can do it in 7 that would be great, the good thing about the drive is it's all two lane rural so I won't have to worry about winding it up too much until I get back to Boise and turn east, then I have about 10 to 15 miles of interstate to deal with and then drop back off on two lane again. I will also bring two five gallon gas cans with me, I would assume it will get about 10-12 mpg's! eek
Mopar or no car
'93 W250 Ram
'68 Charger
Re: D600 [Re: mopeman] #2656455
05/18/19 01:09 AM
05/18/19 01:09 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I don't know how this truck is equipped but if it's like most then 50-55 is wound up.
67 Charger 383 auto
Re: D600 [Re: dodgedon] #2656465
05/18/19 05:40 AM
05/18/19 05:40 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
10 to 12 mpg, idling downhill. More likely 6 or 7.
Angry white pureblood male
Re: D600 [Re: dodgedon] #2656662
05/18/19 07:25 PM
05/18/19 07:25 PM
Id
Id
361 2bbl, 5-speed, and 2-speed rear.
Mopar or no car
'93 W250 Ram
'68 Charger
Re: D600 [Re: mopeman] #2656712
05/18/19 10:50 PM
05/18/19 10:50 PM
ND
dodgedon Offline
dodgedon  Offline
ND
And if its like ours trucks, has a 6.80 gear ratio...
67 Charger 383 auto
Re: D600 [Re: mopeman] #2657035
05/19/19 09:34 PM
05/19/19 09:34 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
It is going to flat line with a working governor. Don't expect anything much better than 8mpg.
Re: D600 [Re: NITROUSN] #2657060
05/19/19 10:12 PM
05/19/19 10:12 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
my brother did a nationwide search for a travco (liked the look) and bought one in georgia and it looked ok to drive home-----couple hundred ,miles out he threw a belt and the hoses were leaking---he ended up camping at a napa store until the correct belts and radiator hoses were sourced......rest of the trip was just fine....
Re: D600 [Re: NITROUSN] #2657096
05/20/19 12:52 AM
05/20/19 12:52 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
You don't get a D-600 for mileage.
It will function just like any other truck of the era.
Good luck and have fun with your new equipment...
I have mechanical Aptitude.
I can screw up anything.
Re: D600 [Re: NITROUSN] #2657345
05/20/19 09:34 PM
05/20/19 09:34 PM
Iowa
coronetville Offline
Iowa
I just got home from driving 1300 miles with a dodge 700 dump truck. I bought all the stuff like you did BUT not 1 thing fit, so i took off anyway. Blew a inside back tire in the first 50 miles, made it the rest of the way on 3 back tires, and got 7 mpg . Nobody has tires for that truck 300 miles is like nothing! Iook out for bad gas,alt,voltage reg. Drive it during the week and get the parts you need along the way, NOT the weekend like I did. Bought it in ID drove to st louis area 50-55 (top speed) Drove from little America all interstate, was no.1 lot of times
Re: D600 [Re: coronetville] #2657426
05/21/19 07:43 AM
05/21/19 07:43 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Originally Posted by coronetville
i just got home from driving 1300 miles with a dodge 700 dump truck. I bought all the stuff like you did BUT not 1 thing fit so i took off anyway blew a inside back tire in the first 50 miles made it the rest of the way on 3 tires and got 7 mpg nobody has tires for that truck 300 miles is like nothing! look out for bad gas,alt,voltage reg, drive it during the week and get the parts you need along the way, NOT the weekend like I did bought it in ID drove to st louis area 50-55 (top speed)
You are DA MAN! bow Sounds like something I would do, though I am getting too old for that... frown
JB Rhinehart, Realist
A-Body's RULE!
Re: D600 [Re: Rhinodart] #2657431
05/21/19 08:05 AM
05/21/19 08:05 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If it has a 6.80 gear and a 40" tall tire, 3800 will get you 66 MPH. It's been forever since I drove one of those but if it has a functioning governor, I seem to recall 3800 was the redline.
There should be a data plate on the door post with all the info like axle capacity, engine, trans and axle ratio.
Kevin
Re: D600 [Re: Rhinodart] #2657562
05/21/19 01:07 PM
05/21/19 01:07 PM
Iowa
Iowa
, well I will be 69 in july, My body tries to tell me NO but my mind wont listen
Re: D600 [Re: coronetville] #2657596
05/21/19 03:02 PM
05/21/19 03:02 PM
Id
Id
Did you get that truck from an auction in Pocatello Idaho?
Mopar or no car
'93 W250 Ram
'68 Charger
Re: D600 [Re: mopeman] #2657641
05/21/19 04:53 PM
05/21/19 04:53 PM
Iowa
Iowa
yes i did
Re: D600 [Re: coronetville] #2657671
05/21/19 06:22 PM
05/21/19 06:22 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
1981 Dodge D150 360 auto
Re: D600 [Re: coronetville] #2657674
05/21/19 06:29 PM
05/21/19 06:29 PM
Id
Id
yes i did
You dirty SOB! rant up I was trying to win that one too. I drove 200 miles one way out there to check it out and drove it around a bit. And to think I was worried about driving it 200 miles back home, well I guess it would have made it. About the tire size, my local Les Schwab has them in stock, I guess that is because I live in a farm community that has a lot of these old trucks in use.
Mopar or no car
'93 W250 Ram
'68 Charger
Page 1 of 3 1 2 3
