413 Industrial questions #2656958
05/19/19 06:05 PM
05/19/19 06:05 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
I have a 413 shortblock with a casting # of 2658836, 4.180" bore, it is turquoise color, has the unique ribs on the side of the block, steel crank with 8 bolt flange, holes ARE tapped on the flange, no centering ring on the flange, all my research says the 8 bolt flanges have un-tapped holes? But what puzzles me the most is there is no casting date on the block, only the casting number mentioned above, number 6 cast into the block in a few places, but no D/N shift indicator and no date, id pad is blank as well, just trying to figure out what year this is, also has 1851535 std RB rods, dished pistons and a gear drive gear on the crank, cam gear is missing. Anybody an expert on 413 industrial/HD truck engines?
Re: 413 Industrial questions [Re: tt76400] #2656993
05/19/19 07:29 PM
05/19/19 07:29 PM
I'm no expert on those motors but my volume #1 casting book shows that casting number as a 426 industrial block with no casting date codes confused
The tapped crankshaft tells me it is a later, after 1962 RB industrial crankshaft, maybe a marine motor to start with work shruggy
IHTHs thumbs
Re: 413 Industrial questions [Re: Cab_Burge] #2656996
05/19/19 07:42 PM
05/19/19 07:42 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
"I'm no expert on those motors", me neither.
Possibly a non automotive purpose.
Electric generator or an Agriculture (water pump) motor?
shruggy
I have mechanical Aptitude.
I can screw up anything.
Re: 413 Industrial questions [Re: tt76400] #2657008
05/19/19 08:14 PM
05/19/19 08:14 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
How far extended is the crank flange from the end of the block? If its out 1"-2" no good, industrial only. Block is strong cold weather block and usually has thick bores.will accept all std parts.
Re: 413 Industrial questions [Re: R/T1968R/T] #2657012
05/19/19 08:31 PM
05/19/19 08:31 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Thanks for the info everyone! I show that casting number used with both a 413 and 426, but this is a 4.180" bore, crank flange is about 1.25" out from bellhousing surface of block, if I use this block, I figure I'd just get a 440 crank anyway, no register for the flexplate, just found it very odd that there are no casting dates.
Re: 413 Industrial questions [Re: tt76400] #2657194
05/20/19 11:10 AM
05/20/19 11:10 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
Quick, put it on ebay as an early prototype MAX WEDGE block, no numbers or dates so the buyer can claim numbers matching LOL beer
Re: 413 Industrial questions [Re: tt76400] #2657235
05/20/19 01:29 PM
05/20/19 01:29 PM
I've used three of the industrial 413 H.D truck blocks to build 426 motors as well as afourth one for my 1963 Plymouth Fury with a 4.150 Mopar stroker crank in it, none of them had real thick cylinder walls after sonic testing them whiney
The first one had a external freeze crack that the machine shop didn't find when they magnafux it, it had a crack cylinder inside also work
I ended up junking that block whiney
On your deal I would have the crankshaft offset ground to BB Chevy 2.200 rod size and increase the stroke to 3.910 and run a set of 7.100 long BB Chevy type H beam rods with a set of custom pistons up scope Make sure and have the block sonic tested and magnaflux before starting so you can decide before starting what bore size, stroke, compression ratio and so on that you end up with up work
Re: 413 Industrial questions [Re: Cab_Burge] #2657334
05/20/19 08:42 PM
05/20/19 08:42 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Thanks guys for the additional info! If I used this, it would be just to build a low budget big block, no stroker cranks, custom pistons, I'm a small block guy, just thought I might try something different, think I'll have to think on this one, least I know what I have and have some ideas of what to do if I decide to build it, awesome help as always! Thanks so much!
Re: 413 Industrial questions [Re: tt76400] #2657363
05/20/19 10:29 PM
05/20/19 10:29 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
I’m a big fan of these engines .... but I’ve never seen one with the crank flange extended. You must have one that was truly an industrial one - like off a oil or water pump OR something out of a large truck. I have about 10 of these and they all came out of a motor home chassis
Re: 413 Industrial questions [Re: dOOc] #2657802
05/21/19 11:01 PM
05/21/19 11:01 PM
dogdays Offline
dogdays  Offline
I wish I was a little closer, Id love to use that particular block to build a cheap ass 472.
The recipe is stock cast 383 pistons, the stock 535 rods, a stroker 4.15 crank. There were only a couple of casting nmbers that show up as either 413 or 426. So the 4.25 bore should be okay. At the time I cooked up this combo one could buy NOS standard 383 cast pistons for $100. That made the stroker pretty cheap cubic inches. Using the stock rods and stock cast pistons I would keep engine speed to 5500 or less and revel in the torque.
It could use a pretty basic head even a cast iron head like a 452 or else one of the lower perf aluminum. 400 hp or less with a high flat torque curve.
OF Course anything you can do with a 413 block you can do better with a 440 or 400 block. But 472 cheap inches could move a big Chrysler or a pickup with authority.
R.
Re: 413 Industrial questions [Re: dogdays] #2657833
05/22/19 12:42 AM
05/22/19 12:42 AM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
dd ... I picked up some of those NEW forged replacement 383 pistons JSTA for that potential projects.
