Re: offset MC adapter?
[Re: mopower440]
#2656756
05/19/19 08:01 AM
05/19/19 08:01 AM
Posts: 6,250 nowhere
Sniper
nowhere
Not sure what application your M/C came from but the ones I use match the 9/16-18 and 1/2-20 port sizes. Generally, I have found that the M/C I use have the recess for the manual pushrod retainer, even if for a power application 79/80 Aspen/Volare has a two bolt manual M/C. As for the offset, this is what Mancini has to say A longer pushrod is required due to the thickness of this adapter. The pushrod also needs to be relocated to the other side of the brake pedal. Adjustable brake pushrods are available from vendors such as Mancini Racing.
[Re: mopower440]
#2656848
05/19/19 12:09 PM
05/19/19 12:09 PM
RapidRobert
and use the newer 2 bolt MC. PB can use a MC with or without the piston "thimble" MB recess so have your parts man pull one in the bore size you are after & a quick look to see if it has it & if so you're set. EDIT I missed that Sniper had already shared this & I would think there are adapters somewhere for the fitting difference.
[Re: RapidRobert]
#2656933
05/19/19 04:47 PM
05/19/19 04:47 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
and use the newer 2 bolt MC. PB can use a MC with or without the piston "thimble" MB recess so have your parts man pull one in the bore size you are after & a quick look to see if it has it & if so you're set. EDIT I missed that Sniper had already shared this & I would think there are adapters somewhere for the fitting difference. .. But im assuming that all the power brake master cylinders wont have that recess though..or do they have it normally anyways?
[Re: mopower440]
#2656969
05/19/19 06:39 PM
05/19/19 06:39 PM
RapidRobert
Just thinking out loud here, is it possible to (in addition) RAISE it a bit?
[Re: mopower440]
#2657001
05/19/19 08:05 PM
05/19/19 08:05 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
"Quote" how do i attach the lines to the newer MC without cutting and re-flaring the lines for the different size, which i would rather not do..?
You should be able to find the brass fitting that adapts from one to the other at your local hardware store,
I have mechanical Aptitude. I can screw up anything.
[Re: mopower440]
#2657006
05/19/19 08:12 PM
05/19/19 08:12 PM
bboogieart
Lost and Spaced
these dang fenderwell headers... You need to re-engineer that whole assembly. You will be cooking your brake fluid.
