Re: Copper Spray on Fel-Pro 1039 Head Gaskets?
[Re: Mr onetwo]
#2656471
05/18/19 06:35 AM
05/18/19 06:35 AM
Posts: 2,928 A shed in England
Tig
A shed in England
Never used anything on Fel-Pro head gaskets, I always re-torque after the first fire up as per the instructions.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: 6pakdakota]
#2656495
05/18/19 09:08 AM
05/18/19 09:08 AM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I never used copper coat on 1039’s and never found a need to retorque them.
[Re: pittsburghracer]
#2656546
05/18/19 12:23 PM
05/18/19 12:23 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
I never used copper coat on 1039’s and never found a need to retorque them. Me too Teflon coated gaskets don't need cooper coat or any other gasket sealer Beaded steel or solid copper gaskets ,yes
[Re: Mr onetwo]
#2656585
05/18/19 02:16 PM
05/18/19 02:16 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks guys ....dry it is I’m a big laquer thinner user. When I go to put the heads on I lower the pistons evenly and throughly clean my block deck and head sealing surfaces with thinner. Clean is your friend
[Re: Mr onetwo]
#2657599
05/21/19 03:11 PM
05/21/19 03:11 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Mr onetwo -- Simple rule of thumb: Fiber-faced gaskets require no chemical sealer; metal-faced gaskets should use a thin supplementary sealer coating (unless they are MLS design). Read the Fel-Pro instructions... I wrote them when I was a gasket engineer with them.
The old-fashioned Copper Coat is for metal-shims.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2657753
05/21/19 08:51 PM
05/21/19 08:51 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have always used a light coating of spray gasket sealer on any head gasket I ever used. I figure a light coating cant never hurt any and could help it seal up. Never had a problem and did the same on my Comedic gaskets on my old 440 that I built in 2006 and is still running fine. I have the Felpro gaskets on my eng in my car now and they got a light coating. This eng has been in the car since 2011 and never any issue's and never been apart. Ron
[Re: Mr onetwo]
#2657892
05/22/19 08:50 AM
05/22/19 08:50 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Is the copper spray needed on normal gaskets? NO, probably not. Will it hurt anything? NO. I've done it both ways and never had any problems. I use copper spray every time on cometic or any other type of steel gasket.
[Re: jlatessa]
#2657996
05/22/19 01:05 PM
05/22/19 01:05 PM
Mopar Mitch
The application of copper spray (or any other kind of added sealer applied by the installer) is a complete waist of time (and expense). The Fel-Pro gaskets already have a micro-sealer, which is furthermore an anti-stick coating for clean and easy gasket removal if/when needed. You've already paid for it when you purchased the gaskets.
In more recent years, some manufacturers of MLS gaskets have a supplementary sealer additionally applied at the end of the manufacturing process.
For single-shim old-fashioned original embossed metal gaskets (such as the very old and original BB head gaskets), that is where a thin coating supplementary sealer could be used. And the copper coating is marginal... a "hi-tack" spray coating is better for those as it will have slightly better viscosity.
IF the surface finishes are very good, and without pitting or corrosion, then realistically, there's no need for supplementary coating to be applied at all.
Mopar Mitch
