Re: Wire Harness Pin
[Re: Jwilli500]
#2656264
05/17/19 01:15 PM
05/17/19 01:15 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
Guess I should've just linked to the part too, so here that is, but the thread discusses ways to get it a little cheaper...
https://www.dormanproducts.com/p-78790-645-506.aspx?year=2004&make=Dodge&model=Ram%25201500&parttype=Door%2520Wiring%2520Harness&origin=YMM
[Re: ct440rod]
#2657316
05/20/19 07:59 PM
05/20/19 07:59 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
Show us a picture of the connector and we can probably tell you how to remove the pins. There are several different style of connectors, each with its own process for removing the pins. Not all off us have a 2007 Ram to go look at. Gene
[Re: poorboy]
#2659332
05/26/19 12:21 PM
05/26/19 12:21 PM
Posts: 395 Milan Ohio
ct440rod
Milan Ohio
Hope this helps
[Re: ct440rod]
#2660953
05/31/19 01:40 PM
05/31/19 01:40 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
There is probably a spring loaded retaining tab on one side of the connector that needs to be press down so the connector will slide out, I use a small thin needle to get mine out on the earlier plugs, I push it in from the opposite side from the wire and pull on the wire while working on them, lots of fun You can do THIS
