4.7 engine in 2006 Ram 1500 #2655956
05/16/19 10:03 AM
05/16/19 10:03 AM
U.P. ,MI.
P
plumcuda Offline OP
plumcuda  Offline OP
P
U.P. ,MI.
It's time for me to get a newer truck..I found a really clean 2006 Ram 1500 with the 4.7 and 123,000 miles. I don't have any experience with the 4.7 but it runs and drives great. I'm wondering how does the 4.7 hold up? How many more miles can I expect? I don't tow anything...maybe haul my 4 wheeler once in a while. Just looking for first hand experiences.
Re: 4.7 engine in 2006 Ram 1500 [Re: plumcuda] #2655965
05/16/19 10:32 AM
05/16/19 10:32 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 4.7 engine in 2006 Ram 1500 [Re: plumcuda] #2660589
05/30/19 11:51 AM
05/30/19 11:51 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I bought my wife an 04 Dakota 4 door truck a while back, with a locked up 4.7 motor. It's a nice little truck, and I got it dirt cheap. I bought a remanned 4.7 from Powertrain to put back in it. They do a lot of upgrades to their motors that other remanufacturers don't. They use better pistons with coated skirts, and they have drilled out and polished the oil return holes for better flow. They install new valve seats in the heads, and pin them in so they won't drop out. They also use a multi layer steel head gasket to help prevent the head gasket issue. I'm a few days away from starting it up, as I just got it dropped in the truck with a low mile 545 RFE transmission, right before we left for the beach. I'll be honest, and say I was gonna drop a low mile 5.3 LS motor in it with a 4L80E transmission, but we live in a smog inspection county and the GM ECM to run the engine/trans would not pass. You can about stand back and throw an LS in a Dakota if you were strong enough! I think the new 4.7 and 545 will last as long as she wants/needs the truck. I change oil every 3K miles, and stay after maintenance...so I ain't skeered of no 4.7! tonguue
Re: 4.7 engine in 2006 Ram 1500 [Re: JDMopar] #2660629
05/30/19 02:01 PM
05/30/19 02:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Those things you mention are sales gimmicks, the factory pistons are coated skirts and don't fail, valve seats only fall out if very severly overheated, oil return is not a problem on these like it is on a 2.7. Good upgrades would involve the timing chains and chain guides and something to keep the rockers from falling off after sitting a long time.
Re: 4.7 engine in 2006 Ram 1500 [Re: HotRodDave] #2660707
05/30/19 06:43 PM
05/30/19 06:43 PM
JDMopar Offline
JDMopar  Offline
I took the heads off my old motor before I sent it in as a core, and the skirts were definitely not coated. I took 2 pistons out to free the motor up and make it turn before sending it in. There is an upgrade to a new type of chain tensioners, with some type of new design plastic or Teflon. It hopefully won't sit long enough to spit out a rocker arm, as is common in wore out motors. There's some kind of rocker arm fix on the market for 4.7 and 3.7, but I've wondered if it's a snake oil salesman!
